Question about Western Digital (WD3200JS) 320 GB Hard Drive
External hardrive problem
My removable disk can't be detected by my laptop, but in the device manager hardware devices it it showing my device, I was unable to access the data to it because it's not showing in my computer devices. I tried replacing the USB connector thinking that the problem lies in there, but the same problem I am having. When I connect my device to other computer, the device is detected.
    Problem Solver:
  • 11 Answers
You probably need to install some drivers for it before it if you see a question mark in your device manager. wich one i don't know, have to google it yourself. no question mark? then i can't help you at all and am sry for that. gl
Posted on Nov 24, 2008
Sony HD-EG5 is not detected on my laptop
Download the "password protection manager" software from the Sony website. When installed it will detect your Sony External hard drive.
Jun 13, 2013 | Sony 500gb External Hard Disk Drive, Usb...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
I have an external simpledrive hard drive, my computer won't detect my hard drive. i know it works, the light is still on, but the little popup window won't show up and it won't show in "my...
Try another usb port. If your using a desktop, try the usb ports at the back of the tower. Also use a shorter usb cable. Long usb cable has the possibility that a power lose will occur. Shorter usb cables has more direct power output going to the external hardrive. Also check your usb drivers in your device manager if it has errors. Right click on My Computer icon on the desktop, then choose Properties, then go to the Device Manager tab then click on the Manage Devices button, there you can see all your hardwares if they are working fine.
Jan 13, 2011 | SimpleTech SimpleDrive 160 GB External USB...
Hardrive not detected
You may have a hardware fault.
Try re-seating the hard drive.
Then check the BIOS to see if the hard disk is detected.
If the hard disk is not detected then either the hard disk is faulty or the disk controller on the motherboard is faulty.
To further test the hard disk, remove the hard disk and connect it to an USB hard disk adapter and plug it into a working computer's USB port. If this computer cannot see it as an external hard drive nor can you open the various folders and files, then the hard drive is faulty.
Then you need to replace the faulty hard drive, install Windows on the new hard drive, together with the laptop's device drivers and your programs to get a working laptop again.
Feb 25, 2010 | Asrock 775i65G Motherboard
Hi, I have an external hard drive GHD225U40 that
go to device manager on computer, (while the external hardrive is connected) find the drive on the list and right click it or somthing, and look to see if you can update any drivers on it..this is more then likely your problom because when you switched from xp to 7 it might have wiped out the drivers for the external hardrive
Nov 13, 2009 | IOGear (GHD125C40) (DHGHD125C40) 40 GB...
When I connect WD 250 GB external harddisk ..I am getting error message" USB device Not recognized due to malfuction"..please guide me my laptop is toshiba and operating system is windows xp
Please trouble shoot by trying the device on another laptop.
If it works on another system, it simply means it is not compatible with yours and you have to get a device that is compatible with your toshiba system.
Good try.
Oct 17, 2009 | Western Digital WD Passport 250GB Portable...
Western Digital External HDD not appearing in My Computer
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Assuming OS is Win 2000/XP/Vista
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Jun 20, 2009 | Western Digital Passport 320GB External...
Disconnect the USB drive
Boot to Safe Mode (F8 at boot), then open device manager (Right Click MY Computer, Properties, hardware tab, devicemanager button) then find the USB Root hubs and delete them
Reboot in the normal mode, go back to device manager, usb root hubs, right click each, properties, power management tab, uncheck the check box to let windows power off the hub (On by default)
reboot, connect drive, see if it detects.
If it doesn't. open Disk Management (Click Start, click Run, type compmgmt.msc, and then click OK.
In the console tree, click Disk Management. The Disk Management window appears)
and see if it is seen then but has a conflict with the drive letter.
If that doesn't resolve, try drive on another system.
Jun 24, 2008 | Computers & Internet
External harddrive
Sounds like a dead hard drive if 2 pc's won't recognize it.
Does it show up in device manager?
(Rightclick my computer click properties->hardware->device manager->disk drives...or click other devices instead of disk drives .)
Check for it in control panel->administrative tools->computer managerment->disk management too.
If it's not showing up get a replacement (assuming its under warranty).
Jun 13, 2008 | Computers & Internet
No external hardrive recognition
It could be that the drive is not formatted/Initialized as yet! Right click on "My Computer" the click on "Manage". Go to(click on) "Disk Management". If the initialize disk wizard comes up automatically then just follow the wizard cause that means your disk needs to be initialized. On the right pane you should see all the disks and their status. It could be that your disk is un allocated. Look for the disk that is full black(black means unallocated), right click on the disk and click on "Create Partition" Follow the steps of the Create Partition Wizard( It will give you the option to format, DO THAT! If when you right on the disk and all that shows is "Initialize", then do that! and go back and create the partition! Hopefully that should do the trick!
Feb 26, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Western Digital (WD3200JS) 320 GB Hard Drive Logo
220 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
