Question about Pentax K100D Digital Camera
Dropped my pentax k100d. Lense is fine, Camera says card locked, will not delete or fire shutter. Sent for repair, was told circuit board was damaged and quoted £306 for repair. Is it possible to buy a new circuit board and have it fitted as I can not afford the quoted amount on repairs, Also this a great camera.
    Problem Solver:
  • 14 Answers
Your best bet is to try a local camera shop and have them fix it. Cameras are dangerous to disassemble yourself because of extremely high voltage electronics that can kill you if you touch the wrong parts. I had a K100D and it's circuits were also fried at one point, so I can sympathize with you. Try taking it to a local shop and seeing if they can beat Pentax's price. Odds are good they will try, but do not attempt this yourself. Even if you could find the parts (which you likely can't) then you will end up better off having it professionally fixed.
Posted on Mar 01, 2011
My Pentax K100 DSLR is flashing "av" and will not take a photograph, though the shutter works fine and takes pictures without the lens.
"AV" means apeture priority. This means that you set the apeture that the camera will use, and it decides the shutter speed. The flashing "av" means that you've picked an apeture that the camera can't pick a suitable shutter speed for at this light level. I would suggest picking a different apeture, or switch the camera to full automatic mode via the dial on the top left of the camera.
Mar 03, 2011 | Pentax K100D Super Digital SLR Camera
New Pentax K100D Super, shutter does not work. Av -- flashing 688 under battery sign. Replaced new batteries did not resolve problem
I suspect dirty contacts on either lens or body. Clean contacts. Should alleviate problem. This happened to my K100d.
Dec 11, 2010 | Pentax K100D Super Digital SLR Camera
My Pentax K100D has suddenly stopped working. It hasn?t been bumped or dropped or anything. A few days ago I was still taking pictures, and then a day or two later when I tried it, it wouldn?t work. When...
Hi there as per your mentioned sound or noise is says that the problem create by your camera lens guide pin. Its damaged or dislocate. So i also suggest you to visit the service center. Thanks.
Apr 03, 2010 | Pentax K100D Digital Camera
What Memory Cards will work?
Hi,,
Unfortunately, the Pentax K100D is not SDHC compatible, which means that the camera can be equipped with a maximum memory capacity of 2GB.
It is also advisable to choose a fast version of the Secure Digital memory card, such as Ultra II or Extreme III by SanDisk. I would recommend using a memory card of at least 512MB, or even 1GB if you can.
Hope this info helps
Dec 03, 2009 | Pentax K100D Digital Camera
Camera only fires in flash off mode, can't take photo when flash is needed
Sorry but, most probably, you have to have your camera repaired at a shop. When you turn the flash on the camera is waiting until the flash capacitor gets charged, so that the lighting is possible. When, due to a malfunction in the flash circuit, the cap doesn't reach its full charge, the camera waits forever.
Oct 01, 2009 | Pentax K100D Digital Camera
Memory Card error message
The K100D works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot is is electronically incompatible.
Sep 25, 2009 | Pentax K100D Digital Camera
My pentax k100d has a memory card error
Trun the camera off and remove the batteries. Leave it for at least a minute before inserting the batteries. Put the car in and turn the camera on.
The firmware in these cameras can get confused. Removing the batteries for a minuite or two will allow the camera circuits to discharge and so it will reset from start when powered-up again.
If this does not work then the camera may need to be sent away for repair. This need not be expensive it could be as simple as re-programming the camera. (Their program memory is writeable and so it can be accidentally altered under certian circunstsances. It may be possible to do this yourself using the downloadable firmware upgrade, but I would let someone else try thet first!)
However, it is just possible that the new card is also faulty!
Check the cards in your PC by obtaining a SD card reader to allow you to plug it directly into your PC.
For reference I would always recommend inserting and removing memory cards with the camera turned off. I would also use the SD card reader to load the images into the PC. Unplugging devices form the USB port can be harmful to some devices. Check the bottom right of your PC screen for an 'safe unplug' icon when things are plugged in.
Oct 01, 2008 | Pentax K100D Digital Camera
Bad USB conection?
I assume that you are using Win.XP,
- did you check; System Properties>Hardware>Device Manager
Is there anything like yellow exclamation etc, especially on the USB section?
- Is it BIOS USB function enabled? Maybe disabled by accidentally.
- You said nothing working through USB, all ports are same?
If this ocurred all of a sudden, than I think you have a software problem.
I have a K100d, its been seven months now and ~6500 photo. My USB cables&fittings are fine, I always using USB port to transfer photos, no problem at all.
I hope your problem will be solved in a short time.
Sincerely
-halotheracer-
Feb 05, 2008 | Pentax K100D Digital Camera
Shutter on k100d
Maybe you can try sensor cleaning mode;
Go to Menu>Set-up>Sensor cleaning, press right than choose "Mirror Up", wait a moment than power off the camera. Maybe this can help.
Regards.
-halotheracer-
Jan 12, 2008 | Pentax K100D Digital Camera
Pentax K100D Digital Camera Logo
138 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
