Question about Sony RM-V310 Remote Control
My sony rm-ed007 broke. i was having problems with the 2580 buttons then 179 started to get temperamental. now the whole remote has stopped working completely can i do anything to fix it, that doesnt mean me replacing the remote. thanks.
You need to open the casing. With a small flat-head screw driver slide it down the crack between top and bottom casings on both long sides with care and you will be able to open up the remote. Remove the top and you will find all the rubber buttons in one piece. Remove the rubber buttons and clean the underside of this rubber pad with alcohol. Also wipe the underlying circuit board with a small amount of alcohol to remove any grease.
You need to take care when re-applying the round menu ring as it only sits properly in one orientation.
Then you can put it all back together by snapping the top back on and you are good to go.
Posted on Oct 30, 2011
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Cant enter self diagnosis on kdf-50e2010
This needs to be done with a Sony remote----almost any standard Sony Tv remote will allow you to do this.
Mar 11, 2012 | Televison & Video
Dear Sir, Can you please inform how I can open and close again after repair my RM-ED007 remote control for the Sonny Bra. I would like to thank you in advance for your assistance Best Regards
hello, you push a small screwdriver through the side of the remote control
turn it gently until you hear a klik. and then you do the same all around the remot.
good luck!
Feb 14, 2011 | Televison & Video
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Aug 24, 2009 | Televison & Video
Sony RM-VL1000 stopped working
Dump the Sony "Integrated Remote Commander RM-VL1000" and go to WalMart (or wherever) and purchase any other brand and model for under $15.00.
You'll be so much better off!
Mar 21, 2009 | Sony RM-VL1000 LCD Remote Control
Remote model [AV SYSTEM 3] RM-SS880 not working :
Need remote code for this home theater. I have Sony RM-V210T universal remote but cannot set it up to work with dav s880. Only PLAY button is working...
Mar 19, 2009 | Sony (RM-SS880) Remote Control
"AMP" button on Sony RM-VL 900T stopped responding
Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
To reset all functions for a Component: Press and hold [S] until the green indicator lights. All Component Select buttons will flash. While holding [STOP], press the desired Component Select button.
Dec 27, 2008 | Sony RM-VL900 Remote Control
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Sony RM-V310 Remote Control Logo
1,341 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
