Question about i-mate JAQ Pocket PC
How to connect my imate jaq to pc. - i-mate JAQ Pocket PC
  • 3 Answers
SOURCE: Synchronise and connection problem in Imate jaq
hello! pradeep
let me tell u if u r using windows XP as an operatin system
then activesync creates some problem it is better to download activesync 4.5 which is the latest one and your problem will be solved. you can download it from net...
Posted on Jan 29, 2008
  • 4 Answers
SOURCE: I CANT CONNECT MY IMAte JAQ TO MY PC
Check Activesync settings if USB connection is enabled.
Activesync > File > Connection settings > Check "Allow USB Connection"
Posted on Feb 06, 2008
SOURCE: imate jaq having problem to connect the pc
I have problem to conect with my PC with imate jaq so p/l let me know at ashok_manandhar@hotmail.com
Posted on Oct 26, 2008
fossildude
  • 832 Answers
SOURCE: imate jaq gprs and outlookmail settings
hi thanks for using fixya!!!
I really suggest if you can contact your Network Service Provider to send you the setting of your GPRS, they can send you over-the-air or you may call them or drop by to their offices and they can set it to you manually. It will be easier and will be more specific.
Hope it helps, if you need further, let me know.
Don't forget to rate my simple solution positively! thanks!
Posted on Mar 16, 2009
SOURCE: i wanna pc suite of imate jaq
touch screen is not working and it asking aling screen please tell me how to skip
Posted on Mar 04, 2010
Tip
Hi, i got new Imate-jaq. I am facing problem in synchronising the imatejaq with...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Dec 28, 2007 | T-Mobile MDA
I wanna pc suite of imate jaq
Feb 20, 2010 | i-mate JAQ Pocket PC
Imate jaq having problem to connect the pc
Sep 07, 2008 | i-mate JAQ Pocket PC
GPRS setting for Imate JAQ
i have aitel sim card. please give guide for internet mobile office setting
May 21, 2008 | i-mate JAQ Pocket PC
INTERNET SETTIN
on your i-mate JAQ go to programs>internet sharing>connect.
prior to this pl make sure that your pda is connected to ur desktop via USB cable and it is synked with the desktop.
rgds,
May 10, 2008 | i-mate JAQ Pocket PC
I-mate jaq
my imate jaq doesnt connect to my pc. Is this a problem related to drivers. If yes, then I suppose the installation cd does contain a driver please advice.
Jan 18, 2008 | i-mate JAQ Pocket PC
hello! pradeep
Dec 28, 2007 | i-mate JAQ Pocket PC
i-mate JAQ Pocket PC Logo
99 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
