Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
Sensorlogic dishwaser 50879 the problem is that after just few minutes it stops and blinks e.g on 26min and I must push the button again and then it continues. It may also stop at other "minutes" during the programme. It seems as if the digital side of the washer needs to be "reset" in someway
3 Suggested Answers
  • 174 Answers
SOURCE: I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Posted on Jul 19, 2010
Daniel S
  • 4323 Answers
SOURCE: We understand that your problem is: My AEG
Hi
The issue is either with a bad door lock-switch assembly or the timer/control has gone bad. Though I believe as the unit starts however, stops in middle of cycle it is the timer that should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 20, 2011
Can you advise me how to increase the temp in my hot tub? Jazzi SKT338H. It seems to be working properly but I don't have the manual anymore
Either turn heat control dial up, or there should be a 2-button, one UP & another DOWN. Push UP button.
If a single Heat button, the push the button once, it will start to blink, then push again - if temp goes up, you are going in the right direction to get to your desired temp. If going down, then stop & wait till blinking stops - then push the heat button again, it will blink again, press again and now it should go in opposite direction.
Apr 19, 2015 | Pool & Spa
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
Jun 13, 2009 | 2007 Honda Accord Sedan
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Changed Electronic control on Kenmore dishwaser
Sounds like wsh motor is not running. Test cycle by pushing in order: hi temp, air dry, hi-temp, air-dry. All lites come on and unit will run. Should hear motor running when 'washing' light is on. If not then motor is bad or something stuck in impeller area. Please leave feedback.
Nov 25, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Pioneer super tuner3d
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
Nov 16, 2008 | Pioneer DEH-1600 CD Player
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
228 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Kolbrun...
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
