Question about HP Compaq Presario V6133CL Notebook
I want to upgrade the RAM in my Compaq Presario V6133CL, but the manual doesn't say, which type of memory i can use. The Product Specifications on http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00762270&lc=en&dlc=en&cc=us&destPage=document&lang=en&product=3250970#N24 doesn't say anything about it too. Does anybody know, which type of memory i can use? DDR2 System Memory says nothing about the MHz or anything else.
  • Adnan Bhatti
    Adnan Bhatti Nov 13, 2010
    The exact specs can be found from the BIOS. Minimum speed of the memory should be equal to the bus speed (FSB) of the processor. Or you can remove the RAM and check the sticker; it says all.
    Genius:
  • 1,542 Answers
HI
If you go to www.crucialscan.com give permission and it will scan your computer and tell you anything you want to know about your memory installed also normally gives you upgrade options as well
have fun
Posted on Nov 13, 2010
What processor and where can I get one?
This 'notebook' was shipped with an AMD Turion 64 X2 Mobile Technology TL-58 CPU, See http://www.cpu-world.com/cgi-bin/IdentifyPart.pl There are three variants. This CPU is "probably upgradeable" according to the FAQ in the pages linked to from my ref.
The HP webpage for this model is Compaq Presario V6642EM Notebook PC Product Information and the specifications (linked to from that page) are here Compaq Presario V6642EM Media Center Notebook PC Product Specifications
The maintenance & service Guide might tell you which, if any, other CPUs can be fitted.
HP say follow the following steps to determine which CPUs are available for your PC HP and Compaq Desktop PCs Upgrading or Replacing the Processor but I don't hold out much hope as to determining the m/b type.
Incidendentally this model can accept up yo 2 x 1GB RAM
18.January.2016
Jan 15, 2016 | Compaq Computers & Internet
How to add RAM TO MY COMPAQ Presario CQ56
First make sure that you can upgrade RAM on that type (look in the users manual), then buy the correct type and open up the machine. The user manual will also show you were they are installed.
Sep 07, 2014 | Compaq Computers & Internet
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
2.6 volt ram
For the Compaq Presario SR1920NX?
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3184154
Product information > Product specifications > Compaq Presario SR1920NX Desktop PC Product Specifications,
Memory:
PC3200
That is DDR Sdram, that operates at a maximum frequency rate of 400MegaHertz. (400MHz)
JEDEC voltage standards for DDR Sdram is 2.5 Volts,
http://en.wikipedia.org/wiki/DDR_SDRAM
(Specification standards
Read down )
JEDEC,
http://en.wikipedia.org/wiki/JEDEC
The motherboard, may not have SPD features. (Serial Presence Detect)
Do not know if the ram memory does, either.
SPD,
http://en.wikipedia.org/wiki/Serial_presence_detect
Sometimes it takes turning the computer off, wait 1 minute, then turn it back on. Sometimes it takes 2 to 3 times of this.
If BIOS doesn't set the voltage up 1/10th of a volt, you may have to do it manually in your BIOS Setup (Utility)
Where did you get DDR Sdram that uses 2.6 Volts, and is it high-performance ram memory?
Post the manufacturer name of the ram memory, and it's manufacturer code, in a Comment.
[The normal factory default setting for the ram memory voltage, is 2.5 Volts. I would see if BIOS Setup will allow bumping the voltage up, before I would EVEN think of a BIOS upgrade ]
Regards,
joecoolvette
Jun 02, 2012 | HP Compaq Presario SR1920NX PC Desktop
Need a manual for Compaq Presario SR1130NX manual
1) Compaq Presario SR1130NX > HP Support > Main page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=425917&lc=en&cc=us&dlc=en&submit.y=8&submit.x=5&lang=en&cc=us
In the list go to the right, and click on > Manuals
On the Manuals page;
1) Quick Setup Poster 2 is a diagram of how to connect the computer up.
2) Getting Started Guide is essentially a User Manual
3) Compaq Presario Desktop Products - Upgrading and Servicing Guide;
Describes how to;
A) Open the computer case
B) Replace a Harddrive, or Optical Drive
C) Removing and replacing Ram Memory
D) Adding Add-In Cards in an expansion slot
E) Replacing the CMOS Battery. (CR2032)
4) Part Replacement Guide;
Describes how to;
A) Replace an Optical Drive
C) Replace an Expansion Card (Add-In Card)
D) Replace a Diskette Drive (Floppy Disk Drive)
E) Replace the Power Supply
F) Replace the RAID Controller Card
G) Replace the 6-in-1 Memory Card Reader
Back in the Main menu clicking on Product information > Product specifications > Product Specifications, details out the Compaq Presario SR1130NX specifications.
Clicking on Product information > Product specifications > Motherboard Specifications, A7V8X-LA (Kelut)
details out the motherboard specifications, and at the bottom shows a motherboard illustration and photo.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=425917&lang=en
The Processor socket is a Socket A. Also known as a Socket 462,
http://en.wikipedia.org/wiki/Socket_A
Processor's, and maximum processors supported, are shown in the specifications.
The motherboard chipset is a VIA KM400A, and VIA VT8237
(Northbridge chip = VIA KM400A. Southbridge chip = VIA VT8237)
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
Ram Memory supported is DDR Sdram at either 266MegaHertz, or 333MHz
PC2100 and PC2700 respectively.
2GB Maximum TOTAL Amount
2 ram memory slots.
EACH slot has a Maximum Amount of 1GB.
The graphics expansion slot is an AGP.
(Accelerated Graphics Port)
Uses AGP 8X graphics cards.
Power Supply uses is an ATX form factor.
Approximately 6 inches Wide, 5-1/2 inches Long, and 3-1/2 inches Tall.
Guessing here but it's either a 250 Watt unit, or 300 Watt unit.
Probably made by Bestec, or Delta, or HiPro.
If the above is not what you had in mind, please post back in a Comment.
Regards,
joecoolvette
Dec 01, 2010 | Compaq Computers & Internet
Memory upgrade
First step : Make sure the memory you purchased meets the following specifications
"168pin PC133 SDRAM DIMM" which should be easily accessible from wherever you bought it.
If not, then you can find memory here. that the company guarentee's will work with your system. Also - You want to make sure the memory that was in your system to begin with is identical to the memory you are sticking in it to get it to 512MB Systems that are this old with "PC133 SDRAM" are very picky about what kind of ram you stick in them. Make sure wherever you purchase your memory from, has a guarentee that it will work in the make/model of your computer.
Mar 14, 2009 | Compaq Presario 5000 PC Desktop
Trying to price/find ram upgrade for compaq presario m2000
You can go to the manufacturer website and check on the product model specifications to show you the correct limits. For example, if you have a hp laptop, go to www.hp.com and enter your product model in the search. then look for product specification page and you should be able to verify the memory limits
Mar 10, 2009 | Computers & Internet
Upgrade ram on 12XL125
Specifications for the Compaq 12XL125 state that the system memory is:
64 MB 100 MHz SyncDRAM, shared memory architecture, upgradable to 192 MB - 4 MB dedicated for video memory
This system will not be able to use the ram you are trying to install.  For more about this system go to this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013744&lc=en&cc=us&product=95040&dlc=en
Aug 16, 2008 | Compaq Presario 12XL125 Notebook
HP Compaq Presario V6133CL Notebook Logo
46 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
