You need windows disk to install win98. You can buy it from nearest computer shop. Then insert that disk into cd dvd rom then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then go to boot menu and set first boot device as cd rom then save settings then it will boot with disk follow the procedure.Then type in prompt "setup.exe" after locate windows 98 folder in command prompt. then follow the procedure then it will repair win98 system files. But before that when you power up the computer press F5 key 5 to 6 times then enter in safe mode if you are able to enter in safe mode then run scandisk so it will fix and recover errors on harddrive. Let me know if you need further assistance. Thanks for using FixYa.
