Shinco split air conditioner with error code E4
  • 68 Answers
SOURCE: Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Posted on Mar 26, 2009
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
SOURCE: E4 error message on Dimplex portable air
Ensure water emptied
Posted on Nov 02, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
I have a waves airconditioner. Its not cooling well n after some time show e4 error. How to remove the error? Plz help.
http://acerrorcode.com/tcl-air-conditioner-error-codes.html
This was googled: waves error codes
It showed a page in "images". Stated
"System abnormity" I think. Page was blurry.
Call a tech! Mini splits can be a troubleshooting nightmare! I think its a Fujitsu unit. It would help, and may save you some $$, to call around to find a technician who has worked on mini splits. And maybe find them a 1-800 # that is their tech support # before hand, so if the tech needs it, you have it. E4 is a vague description for a fault. Make sure you have cleaned air filters, cleaned o.d.coil (turn off power at breaker 1st). Changed batteries in remote. Work safe!
Jun 20, 2015 | Heating & Cooling
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
My airconditioner will not turn on using remote control
Check there will be error code: If not check power to indoor is perfect. Error code details as follows
Code E3
Error detail Remote control transmission error(transmitting error)
Inspected unit Remote control.
Code E4
Error detail Remote control transmission error (signalreceiving error)
Inspected unit Indoor.
Dec 10, 2010 | Mitsubishi MSZ-A15NA Split System Air...
E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
May 07, 2009 | Heating & Cooling
Senville Mini Split Error Code
The E4 light on your system is saying there is a commiuntion problem between the inside unit and the outside heatpump unit.Make sure there are no loose wires and you wired it properly,The S wire is the commiuntion link wire make sure it is a solid run between both units.I had the same problem with my system and it was the s wire not making a good connection.
Nov 03, 2008 | Heating & Cooling
Heating & Cooling Logo
674 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
