Question about Nokia E71 Smartphone
Lock code request - Nokia E71 Smartphone
  • 527 Answers
You search for unlock code
you can unlock it here http://www.theunlockarena.com/
Posted on Nov 13, 2010
Phone lock codes
If it is network lock code, you can can purchase such code from any vendors online like Mobile-Unlocker.com
Feb 19, 2014 | Cell Phones
My nokia 3110C is now requesting for a RESTRICTION CODE??????
You can get Restriction code for NOKIA 3110C model phone from
Prounlocking.com and unlock it easily.After Unlock it you can use with other network sim card.Restriction code needed If the phone locked to network...
Oct 30, 2012 | Cell Phones
Truckline cd70 code
pls sir request code model be6053 sirl no 58091711
Apr 24, 2012 | Mercedes-Benz CL55 Cars & Trucks
My phone is requesting for restriction code
If the Phone asking for Restriction code means it locked to network ...You need to Unlock it...You can get the Restriction code at here Simpleunlocking.com/nokia-2730/rs16wp9/ and Unlock it from network lock..
Apr 14, 2012 | Nokia 2730 Cell Phone
N70 puk code
Hello
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Feb 12, 2011 | Master Lock 5400d: Portable Select Access...
How to put lock code
first go to your menu, then tools, when your are in tools, select settings and then general. after selecting general, go to security, here you have some options such as phone lock, pin code request and so on. select phone lock if you want to lock your phone keypad with a code, and select pin code request if you want to restrict access to your fone so that no one else can put it on when you put it off
Jan 01, 2011 | Nokia E63 Cell Phone
Forgot code to unlock channels. How to unlock?
After you set the lock, you will need the secret code in order to:
• view a locked program,
• view the locked TV, or
• cancel the lock.
If you forget the code, you can view the locked TV without entering the code. To do this, simply
press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
code is requested. Unlocking theTV this way is temporary.
To change or permanently cancel the lock:
I. Turn on your TV. If the TV requests your secret code, press
and_ at the same time.
MENU
2. Press _ to view the main menu.
3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
4. The on-screen display will ask for your current passcode. Press
and _ at the same time.
5. The on-screen display will now ask you to enter a new code:
MENU HOME
• To cancel the passcode permanently, press _ or _ .
• To change to a new passcode, use the number buttons to enter a
new code, then press E_R,
IMPORTANT
You must use the remote control included with this
TV. You cannot use a remote control from another
Mitsubishi component and you cannot use "Univer_
sar' remotes from other manufacturers.
Oct 02, 2009 | Mitsubishi VS-55707 TV
Cell blocked
Securing your Shine
Secure your LG Shine and your account from thieves by locking your phone and your SIM card Losing a phone through accident or to a light-fingered thief is annoying, frustrating and potentially very costly, especially if the 'finder' uses your SIM card to make expensive calls. You can, however, lock both your phone and your SIM card with four-figure PIN numbers to prevent unauthorised use.
The first line of defence is to set a SIM card PIN. This means that whenever you turn on your handset you have to enter a PIN code before the SIM can be used. The default PIN code for your SIM is dependent upon your network; usually it will be found in a small booklet that came with the SIM card.
The PIN can be enabled, disabled or changed from the Security menu – but you only get three chances to enter it correctly. After those three, the SIM will get locked and can only be unlocked by entering the PUK (PIN Unlocking Key) which your network can give you. Enter the PUK incorrectly 10 times, and the SIM will be irrecoverably locked.
To activate a PIN code request, open the main menu by clicking on the scroll wheel. Click 9 to access the Settings menu and click 6 to enter the Security menu. The first item is PIN code request - click 1 or OK to open it. By default this will be set to off. To activate a PIN request, click 1; you'll now be prompted to enter the four-digit PIN. When you've done this, click OK, and if the pin was correct, you'll see the confirmation message 'Complete'.
To deactivate the PIN code request, you would simply select Off from the menu by pressing 2; you'll need to enter the PIN code whenever you change this setting.
PIN code request prevents another user from using your lost or stolen SIM card in their own phone. To lock your phone, and thus render it useless to a thief, you can activate Phone lock.
Two levels of handset locking are available. The first - called 'When power on' in the Phone lock menu - is to require an unlock code to be entered whenever the handset is switched on. This can be confusing and irritating when used together with the SIM PIN, so a second option is to only request the handset unlock code when the SIM card has been changed - called 'When SIM changed'. This means that if your phone is stolen, the thief can't use their own SIM card in it as the phone will need a PIN code to unlock.
To activate either option, go to the Security menu (clicking 9 for Settings and 6 for Security from the main menu) and click 2 to enter the Phone lock menu. Click 2 to activate When power on or 3 to activate When SIM changed. In either case you'll be prompted to enter the security code. By default this is 0000. Enter the code and click OK to confirm.
To change either code, go to the Security menu again (clicking 9 for Settings and 6 for Security from the main menu) and click 5 to enter the Change codes menu. To change the handset's security code, click 1 to select Security code, or to change the SIM PIN, click 2 to select PIN1 code. In either case you'll be prompted to enter the old code before entering the new code twice, clicking OK to confirm each time.
Jan 10, 2009 | LG Shine KE970 Cellular Phone
Subsidy password for w377 motorola
Request for subsidy password means the phone is locked to one particular firm eg Virgin or 02, and you've put a different brand of SIM in it.
Subsidy Password is the same as an Unlock Code.
Suggest you either put a SIM in the phone that's the same phone company as the original and therefore works with a locked phone, or request an unlock code from teh original service provider, or try using 84512461 as a Subsidy Code.
Jul 30, 2008 | Motorola Mobility W375 Cellular Phone
Nokia E71 Smartphone Logo
91 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
