Question about Sharp AR-M257 Black and White Copier
Sharp AR-M207 how do i scan an image. get as far as selecting address to send to. then what button to select? thanks
4 Suggested Answers
SOURCE: Sharp AR-M450 can't scan to e-mail
You should use a USB connection from your pc
Posted on Apr 18, 2008
SOURCE: Sharp MX-2300N trying to send image to email address gives error
The new fire wall was set up with a password, free the password on the server setup, that should eliminate block.
Posted on Dec 19, 2008
mickspaceNET
  • 115 Answers
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
I need a printer software to enable me print with my window 7 software
To help you install printer software for Sharp AR-M207, please find the link given below and find the topic mentioned as 'Software' and select Windows xp:
http://www.sharp-cee.com/cps/rde/xchg/scee/hs.xsl/-/html/product_details.htm?product=ARM207
GuruAid.com
Mar 31, 2016 | Sharp Used AR-M207 Copier Printer Scanner
I want to Sharp AR 5316 Driver for Window 7. Please send this driver software my email address. Thank you very much.
Drivers for Sharp AR-5316 are available at Sharp Official Support site. Make selection as under: -
Select
Photocopiers > AR5316 > Windows 7 (32-Bit OR 64-Bit)
Hope it helps! Good Luck!
CreativeTECH
Feb 18, 2011 | Office Equipment & Supplies
Missing my AR 5316 Driver CD. Pleass Send this Driver software my email address.
Select
AR5316 > Windows (XP, Vista, Windows 7 etc) Depending upon the OS you have.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR-M207 all-in-one does not send or recieve fax
dear sir good day the link http://support.sharp.net.au/drivers/driversearch.asp contain the driver for machine but the problem may happen from the tel line or from other fax sender ... so please first reinstall the driver and try to send or receive fax from other one thank you and good luck
Dec 26, 2009 | Sharp AR-M207 All-In-One Laser Printer
AR-M207 default paper tray for fax
push"special function" button, then select "key op prg", then "ok", then enter pin (default is 00000), then select "fax", then "ok", then select "rcv function", then "ok", then "tray selection", then "ok". The rest you should be able to follow your nose.
Feb 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
Main code {22} ->
Sub code {07} ->
Jan 24, 2009 | Sharp AR-M237 Copier
Sharp AR-M257 Black and White Copier Logo
107 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
