Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
My VIP 622 do not comunicate with my LCD via HDMI when i power on i have a green blinking
    Scholar:
  • 25 Answers
Hello, this is Matt Gonzales with DISH Network. When just the green light on the front of the DISH receiver is blinking, the receiver is in recovery mode. Recovery mode can take up to 4 hours, but if it goes past that, try doing a hard reset on the receiver. To do a hard reset, you will unplug the receiver from the power outlet, leave it for 15 seconds, then plug it back in. After doing this, your receiver will go through a rebooting process which can take about 5 minutes. If you have the same problem with the green light blinking, the receiver will need to be replaced. If this is still an issue, please send me an email at matthew.gonzales@dishnetwork.com.
Posted on Dec 24, 2010
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
Problem synching panasonic dvd audio sync with dish network video
Try to run the audio through the TV. through the audio out on the TV. if it has one. For example run the HDMI to the TV. then use the audio output of your TV. to your DVD/Receiver.
Mar 18, 2013 | Televison & Video
Church has two tvs and we hook them up to our Macbook pro and use a progam called Mediashout to play lyrics. When we have both tvs connected through a splitterbox they blink green and the image trembles....
HDMI comunicates between the output device and the tv. The two components sync the comunication pulses. By conecting the second tv the pulses are out of sync. Somehow one tv must become Master. Is there a function on tv2 to turn off the sync puls? Maybe there is a device that will allow 2 tv's to connect to 1 device but it will be more than a splitter because it will have to sync. with the output device and then seperatly sync with two tv's. Good luck
Sep 18, 2012 | Televison & Video
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Connect to a set top box with HDMI?
You should be able to connect. I don't have a Motorola vip 1910 exactly but I did a little research and it seems like you should be able to no problem. I set up <a href="http://netplasia.com">hdmi video cards</a> and it was fairly simple.
May 15, 2010 | Samsung SyncMaster 213T 21.3" LCD Monitor
Dish vip 622 and vip 722k frequent picture freeze and restart
Sounds like a signal strength issue. You may have either a low signal or something like a tree limb is blowing into the signal path dropping the signal strength to a point low enough to causes issues.
Apr 13, 2010 | Televison & Video
I have sharp 37 inch LC-37D44U MY PS3 is not working with it it green lights keep blinking power light and OPC. BUT THE HDMi ports work beacause i checked it with other devices. so i dont know why its not...
Does this happen when you input certain signals to the HDMI2_bing.gif ports? Or all signals (e.g. 1080i, 720p, 1080p, etc.)? And which ports are affected - side HDMI, rear component, etc.?
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)... their first visit allowed my TV to accept signals in the rear HDMI ports (all signals worked well), but then I couldn't get a signal processed via the side HDMI port. At first, just 1080p would not display (caused the OPC/power green light blinking), and after a few days, any signal hitting that port would cause the error lights to come on. But as I said, eventually, a new side board resolved that issue.
Sep 11, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
I haven't researched to actual manuals for your equipment, but I'm guessing that the optical may be disabled when the HDMI is used. You could try using the component video outputs to the TV and then the optical to the Onkyo.
Jan 02, 2008 | Onkyo HTR500 Receiver
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
362 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
