Question about Porter Cable Garden
Slow to pick up speed speed goes up & down till it's gets to peak
  • 1,041 Answers
Here is a Link to one of my Tips:
http://www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Good Luck!
Jim
Posted on Nov 13, 2010
  • Jim Parker
    Jim Parker Nov 13, 2010
    Sorry, but you will have to get rid of the ( http:// ) in order for the Link to work.
    Jim
Why wont my car pick up speed and slow down going up hill.
More than likely it is caused from not getting enough of fuel, Check fuel filter to see if its ok. God-Bless!
Apr 25, 2015 | 2005 Ford Freestar
I installed the wifi router 3 days back. Had some initial problems which i solved using the books in kit. However, speed was very slow. Next afternoon, speed suddenly picked up. It was perfectly fine...
Hello Ahmed,
This may have nothing at all to do with your router, but may be associated with your modem, or cable connections inside and outside the home, or even your ISP.
I recommend you check with your ISP for a service visit to ensure all is working according to specifications.
Feb 14, 2018 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
Just need to adjust the carburetor, H & L not idling properly and now have got both of them out of adjustment. Have cleaned the air filter. Please help
start off with basic settings of 1 1/2 turns out on both of them, then adj the "L" which should be closest to enjine to where you give it throttle it does'nt boog down on acceleration then get ready to adj the "H" which is closest to air filter, keep in mind you should always have a new spark plug and new or clean airfilter on the machine before attempting to adjust it, so anyways bring your saw to full throttle and adj "H" to where it 4cycles just a little, in otherwords run it in a little till peak sound(rpms) then back off till just is on the edge of slowing down or garbling a little. then go back to low speed and make sure it is o.k. then cut some wood at full throttle and see if maybe you can open it up some more with out loosing power. remember a hair rich is better any day than a hair LEAN! Good Luck 2StrokeJim
May 21, 2011 | Garden
My dehumidifier seems to work fine than after about 5 mins. the fan slows down and there is an electrical draw of power for only about 2 secs.then the fan picks up speed till it gets to normal running...
Very interesting. Try plugging the unit into another outlet. One that's not on that same circuit. It may be, that there's another power draw on the circuit, the unit is currently plugged into.
Please let me know what happens. Thanks.
Apr 27, 2011 | Kenmore 54701 Dehumidifier
TUNING THE CARBURETTER
Start with the L or low speed screw at one turn and the H or high speed screw at two turns. To get good responce from idle play with the low speed screw. For top end engine peaking use the high speed screw. Hold the throttle wide open and turn the screw either way till you peak out the RPM'S . Hope this will be helpful. Donnyb60
Mar 18, 2009 | Echo Garden
Lap opt heats up a lot when playing games and it slows down too
During game play, CPU( Processor) and GPU ( Graphic processor have to work alot so it heats up. Normal activity :)
Jan 27, 2009 | Computers & Internet
1994 olds cutlass 3.4 dohc
have you changed the fuel filter lately a plugged fuel filter will cause this concern
did the power loss start all of a sudden or did you start losing power over time ?
Oct 22, 2008 | 1994 Oldsmobile Cutlass Supreme
Pride legend xl
Had a similar problem with my shoprider te888's there are 2 possible solutions that I have found.
1. dirt had been picked up in the pad that acts as a brake, causeing the motor to drag and speed up, found this after almost burning my hand on end of motor with brake. disassembling the brake and cleaning with an alchohol soultion fixed this one.
2. Loose wire to battery post, or corrosion on battery connectors can cause this too. found loose terminal on battery by tightening nut where wire attached.drove me nuts for days till I decided to tighten with wrench rather than finger tight... On my scooter it would slow down do to excessive current draw because of bad connection and controller would shutdown, which meant ubrut stop. Showed up mainly when climbing long grade up driveway.
hope this helps
Oct 16, 2008 | Pride New Mobility Legend 4 Wheel Scooter
Garden Logo
23 people viewed this question
Top Porter Cable Garden Experts
Jim Goldsmith
Jim Goldsmith
Jim Parker
Jim Parker
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
