Question about Hotpoint Dryers
I have a Hotpoint Aquarius Drying System - Dryer Plus 9316 and the belt that goes around has come off the motor. I have taken it apart but I can't seem to put the belt back around the motor. How would I put it back around?
5 Suggested Answers
SOURCE: Squeaking!!!!
depending on the age of the dryer, there is a rear bearing that needs to be replace if its is an older dryer. if its new 10yrs or newer the there is a front bearing support that should be replaced
Posted on Nov 19, 2007
Master_Tech
  • 770 Answers
SOURCE: hotpoint aquarius reversomatic plus tl21
Please post the model number from the unit it is where the door closes to so I can see what is going on
Posted on Jan 26, 2008
SOURCE: Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Posted on Feb 03, 2008
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
I have a Hotpoint Aquarius WD420, the dryer isn't drying its making all the right sounds its spining but the washing is just not drying. Please Help!!!
sounds like the termo stat packed in if you take the top off you will see it. It will have 2 wire 1 on each side it will be round common fault their are around £15 good luck hope this helps
Jan 20, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
E30 flashing when I try to start wash program on Hotpoint Aquariu
E30 indicates a motor problem, you will need to call an engineer.
Possible worn brushes which you can do if you know what you are doing.
Nov 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Broken belt on Hotpoint Aquarius dryer tdl30p
you neen to access the machine from behind you will have to remove the back panel and the tensioner pulled back you should be able to work out where it goes put it around the drum first though its easier
Nov 11, 2008 | Dryers
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machine not spinning
Bring your sample to appliances store let them chech if their available.
Check the heat sensor detach one line test the continuity both terminal if open replace it.
Jan 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
103 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
