Question about Panasonic RP-WF930 Consumer Headphones
Where can i find a local dealer, to replace my batteries. pt./no:HHR-70AAB9B in wolverhampton town centre or surrounding area. Thanks.
Replaced battery on 2002 chrysler sebring now i have no sound from radio
Believe it or not, lots of people on the Chrysler Forum have had the same problem! One guy said, "I have a 2004 Pt cruiser with a factory Mopar radio and 6-cd player. I disconnected the car battery for about 2 hours and replaced it with a new battery. Following that the Mopar radio doesn't show the Cd-player as a selectable option.
I found this statement in a ebay listing for a sound shop selling used Mopar cd players like mine ...
This model radio may need to be programmed at the dealer for it work properly. The dealership will actually program the radio to the vehicle so they can communicate together. The estimated cost to program one of the radio to your vehicles is $45.00 but check with your local dealer for a quote. We do NOT accept returns on radios for this PURPOSE so be sure to research before buying."
Here is the site, but it sort of looks like the dealer has to program the radio. WHAT?!!!! http://www.topix.com/forum/autos/chrysler-town-and-country/TI14P6LNCF47UC82R
I hope this helps you out!
Apr 01, 2017 | Chrysler Cars & Trucks
My hhr 2006 i try to clean the throttle body but now the relenti is to high how i reprogram the throttle body
You need to use the Tech II scan tool from GM to perform this relearn process. You can try disconnecting the battery for 30 minutes, but you more than likely will need the relearn procedure done at your local dealer.
Oct 12, 2015 | 2006 Chevrolet HHR LT
Why is my battery and engine light still on? We just replaced the ECM PCM in My PT Cruiser 2006.
Hi
Try getting a check done on your alternator to make sure it is charging the battery, if your alternator is not charging then your battery light will stay on, hope this helps
Sep 19, 2014 | 2006 Chrysler PT Cruiser
Gunwale replacment old town discovery 169
The yoke is easy -- measure the exact length and buy a new one that you find comfortable from your local dealer or outfitter. Just bolt it in place.
The gunwale is a bigger job, and depends on what it is made of, but a discussion with your local Old Town dealer will help figure that out.
Mar 23, 2013 | Old Town Canoe Old Town Discovery 169...
I have a 2007 PT Cruiser. I replaced a dead battery in July. Same problem in Sept. Again same problem in last week in Nov. Local Midas has been wonderful, replacing 2 batteries for free thanks to...
You need to have the charging system checked. It may be overcharging the battery which would destroy any battery. I would suspect the voltage regulator is defective.
Nov 20, 2010 | 2007 Chrysler PT Cruiser Touring Hatchback
I locked my keys in my 2007 HHR Panel. I do have
you might try going to the dealer and they might be able to cut a key. you can try jimmying the lock. kits and instructions are available. http://www.google.com/search?q=slim+jim+car&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7
May 26, 2010 | 2006 Chevrolet HHR
Gear shift lock will not pop out on 2007 hhr-read many similar problems involving 2006 hhr- any reports or advice for 07 This happened once before but drove the car and it popped out on its own this time...
there were problems with the shift lock control switch and is located in the shifter assembly.must replace the shifter assembly to correct issue.
Mar 23, 2010 | 2006 Chevrolet HHR
How do you replace a blower motor on an 06 hhr
you need to cut out the bottom of the box where the motor sits and get an blower motor attachment kit from local gm dealer
Jan 02, 2009 | 2006 Chevrolet HHR
I need a battery for a Quasar palmcorder the model number is vm-d51
Try go to Wal Mart and get Duracell DR10 6 volt battery.
Dec 16, 2008 | Quasar VM-D51 Camcorder
I need a battery for a Quasar VM-D51 Camcorder and I can't find one. Any ideas?
The Battery you can use in this palmcorder are part numbers 1.HHR-V60A/1B $119.95 6Hour Battery 2. HHR-V40A/1B $69.95 4 Hour Battery 3. HHR-20A/1B $59.95 2Hour Battery. These batteries can be purchased from Any Panasonic dealer or you can call this order telephone number. 1-800-332-5368 between the hours of 6am-5pm M-F 6am-10:30am Sat PT. The prices are subject to change anytime. This information was found in a copy of the owners manual on pages 33/34. You can find a copy of this owners manual at this web address. ( http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man ) you can copy the address and paste it in the address bar of your browser and it will take you to the website.Follow the instruction to download a pdf copy of the manual for viewing. I hope this information helps you with your battery problem.
Nov 19, 2008 | Quasar VM-D51 Camcorder
Panasonic RP-WF930 Consumer Headphones Logo
112 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
