Question about Bose Wave Radio
Bose Wave Radio model AWR1-1W date of manufacture 05/13/98 disply too dim under all conditions.
  • SINE_30 Nov 14, 2010
    Ginko knows his stuff. Thanks!
  • Bose Master
  • 19,396 Answers
Hi.
This is a common problem with this model.
The LCD has a dimmer circuit that can be responsible, in some case it is not the dimmer,regulation, but the LCD control circuit itself.In that case you have no LCD backlight and the display is almost unreadable. If that is the problem, changing dimmer settings with procedure below will not help.
Most of the time the problem is dimmer regulation.
About dimmer regulation:
Try disconnecting the unit power cord for ten minutes and connect back.
Try holding down CD or CLOCK button and pressing at the same time the volume buttons. This procedures regulates Bose dimmers setting in a scale from one to 9. The dimmer has separate settings for medium and low brightness. Set both to 5 if you want to disable dimmer settings.
Posted on Nov 13, 2010
  • twinimage Dec 11, 2010
    And if this doesn't help, you have a bad display, most likely.
    The fluorescent not available anymore, not from Bose not from the company who made it for Bose. I asked.
    I still have about 5 left.
  • KirkHiggins Jan 18, 2011
    Is this something that I could replace myself or does it require a technician? What would a replacement display cost? Thanks I may be reached at kirk.higgins@sbcglobal.net.
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
don.miller60@outlook.com
Nov 30, 2015 | Bose Wave Radio
Why doesnt my wave radio screen light up when the lights in theroom are on ?
That doesn't make sense does it? A few things first.... how bright are the lights in the room? Is the display of the WAVE facing the lights? The radio has a photo sensor that detects light, but for it to be effective, it has to "see" the light. It could be that you have a bad photo sensor, but I would try a few things first. 1. Make sure the light in the room is sufficiently bright. 2. Make sure the display is pointed in the direction of the light. 3. Make sure nothing is covering the photo sensor (like a piece of tape or something.... maybe a previous owner wanted to "turn off" the light". 4. If none of the above get you going, shine a flashlight at the photo sensor (a bright one). This should turn on the display. If this works (and nothing else did), that just means you ain't getting enough light to the sensor under your normal conditions and you will need to correct that underlying problem first,
May 29, 2015 | Bose Wave Radio
How do you get the display light on a bose radio to stay on
Do you mean keep it from going dim in a dark room? The settings menu has "Bright Hi" and "Bright Lo" adjustments you can make in ranges from 1-8 (Lo) and 8-10 (Hi). Check your manual under the heading "The setup menu" for very clear instructions.
Jul 03, 2014 | Bose Wave Radio
Bose Wave Radio/Kindle Fire
Yes, all you need is a standard audio adapter cable that plugs into the earbud jack on the kindle and into the "variable in" jacks on the back of the Bose. (male stereo 1/8" plug to a pair of male RCA/phono plugs).
Dec 11, 2013 | Bose Black Wave Am/fm Radio W/ Remote -...
Following a direct lightning strike to our pole transformer, transformer blown ,, replaced ,, several electronics not working including our Bose Wave Radio (no CD) ... Where can we find repair and how much...
Bose does not release their schematic diagrams or parts lists, so factory maintenance is about the only way to go. You can start the process by visiting www.Bose.com, but be ready for some sticker shock. Before you do anything though, every Bose has a line fuse inside the case. The location varies by model and date of manufacture, but if you open the case it will be simple to locate. Check it, and replace it if necessary. The fuse is there to safeguard electronics against power surges, so it is your likely culprit.
Bill B
Aug 01, 2010 | Bose Wave Radio
My Bose Wave CD Radio has no power. Will not turn on. dead. Checked the power cord and supply, it is good. Is there an internal fuse?
Yes - although Bose doesn't really publicize the fact, there is an internal line fuse in each Wave. Location varies by model and date of manufacture, but the fuse is easy to spot once you open the radio case.
Bill B
Apr 10, 2010 | Bose Wave Radio
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Bose Wave Radio Logo
1,850 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
