Question about Broan-NuTone QT100L Fan
Clicking sound from bathroom exhaust fan - Broan-NuTone QT100L Fan
2 Suggested Answers
maintenacemi
  • 95 Answers
SOURCE: My bathroom exhaust fan makes a clicking noise,
fan blades touching sides of housing,also runs caused by back draught
Posted on Nov 18, 2009
When I'm in my bathroom and showering the light turns red- what does this mean- Mold?. moisture?
The simple answer is moisture. If you have a bathroom exhaust fan, be sure to run it during and after you're showering. Typically, for a bathroom exhaust fan to reduce the moisture properly, it should remain ON for at least 15 minutes after your showering is complete,
Hope this helped to answer your question.
Apr 23, 2011 | Winix PlasmaWave 5000 Air Purifier
The bathroom exhaust fan in our bungalow is leaking this past week every few days , we are not handy folks and so we are wondering what type of professional do we call in to deal with this leak and...
Sounds like the issue is simply condensation inside the exhaust pipe where it passes through the un-heated attic space. If you use the shower and the exhaust fan, lots of humid air is passing over the inside surface of a very cold duct, then running back down to your bathroom ceiling. You could get any non-specialist handyman to wrap insulation around that duct in the attic. But you can mitigate the problem by running the fan for a few minutes before you start the shower (thereby pre-heating the duct before you give it a blast of moist air) , and leaving it run for 20 minutes afterwards (thereby drying out the duct after use). Regarding the discolored ceiling, the handyman can apply some stain-covering white primer too.
Jan 14, 2011 | Fantech Fans Exhaust Fan In-Line
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
There is a part our bathroom ceiling that my husband has spackled 2x and painted and the paint bubbles. We have a fan in there. It started bubbling within a month of him redoing it last time. Any...
if it's around the fan then mabey the fan exhaust pipe is not connected .If it's in the attic you can go up there and checkbut if it's between floors you will have to pull the fan down from inside and check. It sounds like your celing keeps getting moisture from the underside of the paint
Apr 10, 2010 | Home
My parents had a Broan exhaust fan installed in their bathroom and water is leaking from it. Any ideas on what this could be?
Sounds like a condisation problem. Check the exhaust tube for low spots, and also check if the exhaust tube is isulated.
Nov 29, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Motor for bathroom exhaust fan
same problem but l thing l solved it by ordering a new replacement from globalindustrial.com if you need more help email me at hugo698@aol.com
Mar 01, 2009 | Marley PJ1257 Heater
Wireing a bathroom extractor fan to a three switch (fan=landing light=offswitch0
yes, if the three switches are all made together, then there is only one feed. sounds like a bad switch, or possibly bad exhaust fan. check voltage at fan with switch on, if not qualified, be careful, or call an electrician
Aug 10, 2008 | Dryers
New bathroom venting in basement bathroom.
Install a window mounted exhaust fan if you can discharge to the outside of the house surrounding atmosphere.But undercut the door of the batroom to allow air coming in into the room.Alternatively firt a door grill 600 x 150 mm size which is more expensive.THe size of the fan should be 50 to 100 l/s of air flow.
Mar 24, 2008 | Fantech Fans Exhaust Fan In-Line
Moisture on bathroom exhause vent
the fan is pulling too many cfm (cubic feet per minute).you can replace the switch of the fan with a potentiometer type switch (this works like a light dimmer)you can reduce the speed of the fan,or you can use a couple of synthetic fiber filters to trap the condensation.good luck
Jan 04, 2008 | Fantech Fans Exhaust Fan In-Line
Broan-NuTone QT100L Fan Logo
399 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
