Question about ASUS P5S800-VM Motherboard
Hi there.i have a p/bell pc ,it has a P5S00-VM MOTHERBOARD in it.the other day for no reason it just stopped and came up with no video input.tried to reboot but it just freezes after about 10 seconds.if i leave it for a while and then switch it on i can sometimes get to the screen that says media test failure check lead.things i have done are as follows....changed the cable that goes to monitor,taken each ram out seperately,reseated the lan card and sound card,checked for any visual problems,got into bios and noticed that the date had gone to 2002 and so after numerous attempts managed to correct that,tried to check the boot order , but up to now cant get that far without pc freezing up,i have taken battery out to reset cmos settings but all to no avail.i am not too clued up on these matters ,but know just enough to get by.any suggestions ?.im at a loss ,please helpppppppp! thanks ..............andy
  • 136 Answers
SOURCE: major help needed
hi jtiker,
if you have replaced all the parts mentioned above then you will need to reinstall windows as it will try to use drivers from the old windows and create more problems for you.
go to the bios and set it to boot from the dvdrom first then reinstall windows.
your only other choice is to boot in safe mode and try to reinstall the mobo drivers....not recommended though
good luck
Posted on Jan 02, 2008
  • 119 Answers
SOURCE: I changed RAM settings in BIOS, now I can't boot - need to clean CMOS
well its quite have set the wrong latency for rams.
I suggest you put a latency around 3
reset the bios and check the know that you must have all the rams from the computer to the same all the timings or latency.
good luck..
bye bye
Posted on Feb 06, 2008
  • 119 Answers
and by the way,the reset of bios is done by switching the reset jumpers...with the computer off:)..dont get the baterry out unless it is absolutelly necessary.
after that set the data for the ramms.
  • 1913 Answers
SOURCE: no signal check input cable .
when u start the pc press F8 key then go to enable vga mode or safe mode or last known good config...
then set your display resoluiton to 800*600 or 1024*768
thatas all.
Posted on Oct 09, 2008
  • 31 Answers
SOURCE: Emachines T3410 won't boot, black screen, no cursor
hello dear
you say that your hd work on other system,if you istall window from other machine then it will works only at same machine not on others because mb ram store booting information,so try to install window using your mb & then try
if it does not work then tell more aout your problem that is how problem come?
also it may be due to master slave
if ou use hd with removable device then sure that one of them is master &another is slave
Posted on Nov 15, 2008
When i start the pc monitors shows that there is no video input i have checked all cables & also checked another monitor. Plz suggest what is this problem?? (ASUS PSPE-VM)
In that case the problem is in your pc. Try to boot using an add-on video card (not your onboard one) - if it works then keep it and disable the onboard one from the BIOS.
Jun 27, 2010 | ASUS P5PE-VM Motherboard
Need to hook up the power to the power pins on the motherboard, where can i find the manual for an ASUS P5PE-VM Series M-B
You can download the required manual by clicking this link:
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Oct 10, 2009 | ASUS P5PE-VM Motherboard
Motherboard P5PE-VM doens´t get ON
Hi! Good Day, your ASUS motherboard don't have problem it's just that you have to make your CMOS jumper back to the original settings, it's near in the battery terminal. You will see a label on the board saying Close and ClearCMOS, put the jumper in close position then turn on your computer, thats it Good luck
Jul 27, 2009 | ASUS P5PE-VM Motherboard
ASUS P5S800-VM mother board V Asus EN9500GT graphic card
you would need a new mother board or change the graphics card
Feb 11, 2009 | ASUS P5S800-VM Motherboard
Compatible Graphics Card for ASUS P5LD2-VM SE Motherboard
Yes its compactable !! but u can onlt add 1 ;-)
he he...!
Mar 08, 2008 | ASUS P5LD2-VM Motherboard
ASUS Motherboard A7N266-VM
If you have another video card you can try (you can put an AGP card in there, it will disable the onboard video automatically), take that route first. If you can't, or it occurs with another card, it may be your power supply. It would help to know if your pc beeps when you turn it on, and how many - if any - beeps there are.
Feb 18, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
Video driver for asus cuple-vm motherboard
On left top corner > input model to search (CUPLE-VM) - category - drivers - hit search info.
Jan 14, 2008 | ASUS VIA Apollo PLE133 Chipset CUPLE-VM...
Boot error / No video out
The beeps are usually due to RAM or key board issues.
I would try by plugging it into a VGA socket of a monitor to see if it works.
Do you have heat problems? one suggestion is to try and reset the bios to default by moving the jumper on the mobo to do a hard reset.
good luck
Oct 23, 2007 | ASUS M2NPV-VM Motherboard
ASUS P5S800-VM Motherboard Logo
103 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
