Question about Linksys WPC55AGv1.3_v7.1.0.90.exe
CANT FIND FREE DRIVER FOR WPC55AG LINKSYS ETHERNET
Trying to connect to internet cant find wireless & cant find a ethernet place either
The laptop in question does not have a place to plug in the ethernet cable. The laptop is not fitted with wi-fi or bluetooth adapters either. The best and cheapest way to connect this laptop to the internet is using a PCMCIA Card Adapter (type two or three as both are supported.) such as the product supplied by linksys. If yours is similar to the one in the photo then it should include a cable with the required network connection on the end. The "linksys" card you mentioned is no doubt the correct one, but minus the vital cable!
May 20, 2016 | NEC Versa LX Notebook
My Linksys router was working fine with my Compaq Presario until I upgraded to HP pavilion slimline with Windows 7. The slimline has only one Ethernet connection; the Motorola modem also one; and the...
Connect your Linksys router to your Motorola modem through the internet connection on your router. The ethernet ports on your router is for your PC's. The 4 ethernet ports on your router means you can connect up to 4 PC's hardwired to the router. You may also wants to contact Linksys Technical Support Team to assist you on the configurations of your Linksys router.
Aug 31, 2011 | Computers & Internet
Cant get computer to reconize usb ethernet adapter. downloaded drivers from linksys site. when trying to run it says cant run sys. file
how are you installing the driver? did you extract it, if no...then extract it and the install should start automatically.
-mk3ride
Dec 28, 2010 | Linksys Compact 802.11b (WUSB12) Wireless...
I get message says ( you're connected to the access point, but can Not find the internet ?
What is your OS?
The table shown below lists all Linksys adapters that will work with a Windows Vista environment.
I wonder if your OS is Win XP.Post back!
Minimum Requirements
• 400 MHz or Faster PC
• 256 MB of RAM Memory
• CD-ROM Drive
• Avaliable USB Port
• Microsoft Windows 98SE, Me, 2000, and XP
WUSB54GSC version 2.0 is compatible with Microsoft Windows XP, Vista 32 / 64-bit edition with latest updates and Windows 7 32 / 64-bit edition with latest updates
Product
Driver Vista 32 Vista 64 PCMCIA WPC54G V1 3.100.64.0 OK WPC54GR 1.0.3.0/2.0.1.9 OK WPC54GS V2.1 4.100.27 / 3.100.6 OK WPC55AG V1.3 4.1.2.38 / 7.1.0.9 OK WPC100 OK OK WPC600N 4.150.31.0 OK WUSB WUSB54GC V3 OK OK WUSB54GSC 4.1.20.0 OK WUSB54GSC V2 4.118.4.0/4.170.61.0 OK WUSB54GR 1.0.2.0 / 3.0.1.0 OK WUSB100 OK OK WUSB100 V2 4.9.9046.1 OK OK WUSB300N 1.0.7.2 / 1.0.3.2 OK WUSB600N 1.1.0.0 / 2.1.4.0 OK OK WUSB600N V2 1.4.4.0 / 2.3.4.0 OK OK
Dec 07, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Ethernet driver problem
Hello today is 7-22 and I as on a Dell Dimension C521 running Vista Basic AMD 64 and was having a problem with a no driver install in the device manager for the Ethernet Controller. I took out the net card and found the model # on it. mines was a Linksys Support
l,81.png EtherFast 10/100 LAN Card (LNE100TX)I download three drivers one from Linksys/Cisco website:
http://homesupport.cisco.com/en-us/wireless/lbc/LNE100TX/download
and two from this opendrives.com site:
http://www.opendrivers.com/driver/214850/linksys-lne100tx-version-5-etherfast-10-100-lan-card-driver-free-download.html
http://www.opendrivers.com/driver/284251/linksys-lne100tx-network-driver-5.12-windows-98-me-nt4-2000-xp-linux-free-download.html
They all are zip files. I unzip them in the same folder and went back to the device manager and told it to look in the folder and it found it and I am up and running able to connect to the internet.
Jul 04, 2010 | Dell Dimension C521 PC Desktop
Dell XP 200 Dimension ethernet port
Hello.
I'd suggest testing with another computer and the same Ethernet cable to your modem to see if the results are the same and to narrow down which component is the problem.
Was it always slow with this setup or did something change.
Is the Linksys adapter connected via USB ? That would be slower than an internal adapter.
Try updating the Linksys adapter software - Device Manager - rightclick - update driver.
Hope these suggestions help.
Dec 23, 2009 | Dell XPS 200 PC Desktop
Wrong ip address, need to reconfigure
Im assuming youre using an integrated ethernet card since you say "adapter port" and "unplugged". So....
Since you reformatted your HD with O/S re-installation you may also have to reinstall or update it to the correct ethernet adapter driver. As far as the ethernet card set-up - copy your ethernet card property configurations from the other computers. Also copy configuration settings from your Internet Explorer options.
Jan 11, 2009 | Linksys Wireless-G WRT54GS Router...
Network printer
Connect one end of an ethernet cable into the ethernet port on the printer and the other one into a free port on the router. Then, using the install CD, tell it that you are attaching a printer on the network. The software should automatically detect the printer on the network and set itself up for it.
Jun 26, 2008 | Computers & Internet
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
