PRINTER SEEMS TO HAVE DIRT ON THE REEL,PRINTS WITH A SHADOW DOWN THE LEFT SIDE
  • Anonymous Jul 11, 2008
    prints wth are shadow on the right side
  • amhalon Jul 11, 2008
    prints with a red shadow on the right
Clean roller.
Posted on Jun 18, 2008
How can I fix canon mx 452 when it prints a shadow
Are you using a reconditioned cartridge?
If so use a real Canon cartridge
Aug 30, 2014 | Canon PIXMA MX452 Wireless Office All In...
Canon LBP5000. The printer has stated to print a shadow image of the darker parts of the print. Not always from the start but after some prints. The shasow image can also be from the previous print. It is...
Had the same problem with LBP5000. Used the Cleaning Utility(Options/Cleaning) in the printer software, had to run it several times, the shadow did not go away the first time. Looks all right now.
Hope this helps.
Thor.
Nov 08, 2010 | Office Equipment & Supplies
A black line prints down the left side of anything I copy or scan
Probably there is piece of dust, or some dirt (usually a pencil mark) on the scanner glass, which is located under the front panel. Open the front panel and clean the glass with a soft cloth. If necessary, use some liquid cleaner, but put it on the cloth, not directly on the device.
This link might be helpful.
Nov 05, 2010 | HP OfficeJet K80 All-In-One InkJet Printer
Shadow prints in the left side of the paper
hello, if you already changed toner cartridge, and problem is still there, the fuser unit will need to be serviced or replaced.
Oct 11, 2010 | HP LaserJet 1160 Printer
Hi My printer 2600n prints a shadow of the
if logo preprinted may not take heat if everything repeats check fuser
Jul 28, 2010 | HP Color LaserJet 2600n Printer
Image blurs as the page prints
It might be your printer catridge problem. Try changing it and giving it a nozzle clean.
Feb 06, 2009 | Lexmark X3350 All-In-One InkJet Printer
Smudge on left side of paper
It seems like your PCU's are dirty and are picking up extra toner. Take them out and look at the green rollers, any extra finger prints or dirt on them? Clean them with a clean paper towel.
Also, check your transfer unit below the PCU's, that may need cleaning or replacing. You can pull that out after removing both PCUs, turn the little screww and look at it. That can also be cleaned with a cleaning wipe or a damp paper towel. There's a little tab that you can turn to free the rollers (they'll still be a little tight) bu then you can turn the rollers to expose more surface area.
Good luck. Be sure to rate the post if it works for you.
Feb 04, 2009 | Ricoh Aficio CL3500N Laser Printer
Colors do not match up
Have you tried a few alignments? Also you can try turning the printer on and when you start hearing the alignment turn the printer off ... do this a few times and see if this helps.
Also you can try to manually align the cartridges.. to do this turn the printer off. Open the front cover to reveal the cartridges. On the right hand side you can see some gears. Try to turn one of these slightly.. one click (1mm) should do it. Now turn the printer on and let it align itself
Dec 15, 2008 | HP Color LaserJet 2500Lse Printer
Dashed lines printed randonly on the left side
I found a solution for it.
Just adjusting the altitude on the printer settings. I change from plain to higher and the dashed lines disapeared.
May 11, 2008 | Samsung CLP 300 Laser Printer
288 people viewed this question
jasbo
jasbo
