Question about Panasonic Lands Phones
My panasonic cordless phone makes a screeching noise when in use on all handsets.
SOURCE: Dual Maxus 5.8GHz Handset Cordless Phone
After the batteries have been fully chaged, thephones will still not work until the they have been registered to the base unit. Just put each phone in the charging cradle in the base unit for about 10 seconds. The indicator light will blink during the registration. If you are lucky, this may solve the problem.
Posted on Nov 23, 2007
  • 512 Answers
SOURCE: i have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
Posted on Feb 22, 2009
njvinod
  • 1462 Answers
SOURCE: I have a panasonic cordless phone, model
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
Posted on Nov 11, 2009
  • 5102 Answers
SOURCE: I want the user's manual
The handset manual is here: http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/KXTG1100CX-_E (you'll need to rate the product or enter security code to download).
I hope this helps.
Posted on Jul 28, 2010
Testimonial: "It really was useful, as now I can set the settings on my phone and get the ful out of my phone."
SOURCE: Panasonic cordless handsets all say line in use
Return to the manufacturer for replacement. I've spent hours on this and have had my line tested. It's a base station fault.
Posted on Oct 02, 2010
Is there 3 way calling on this model?
[PDF]Operating Instructions - Support - Panasonic
service.us.panasonic.com/OPERMANPDF/KXTG2740S.PDF
PanasonicModel No. KX-TG2740S ... other cordless phone. For Best Performance. 3. For assistance, please call: 1-800-211-PANA(7262) ... •If you use the handset near anothercordless phone's base unit, noise may be heard. .... 2-Way Radio Communication .....&Each mailbox icon will flash if there is at least one new message in the.
Panasonic Product Support - KX-TG2740S
shop.panasonic.com > Get Support
PanasonicObtain product support for Panasonic KX-TG2740S 2-Line 2.4GHz MultiTalk Expandable Cordless Phone System with Digital Answering System.
Jan 21, 2016 | Panasonic KX-TG2740 Cordless Phone
My panasonic cordless phone model # KX-TG2258S the handset works but when you dial or talk or even just pick up the phone you don't hear any noise at all. not dial tone but it does call out. you just...
Do you even hear white noise? If not, it sounds like your phone's speakers may be broken, or it has water damage. If your landline is connected to more phones, ask yourself these questions:
Do all of the phones have this problem? If so, it's a problem with your connection, not the speaker.
Is there a volume button anywhere on the phone or the base? Try turning it up.
Do my phones make a "beep" noise when i push the buttons? If not, did they used to? If they don't, then it's likely that the speaker is no longer working properly.
You may need to contact panasonic and see if they will replace it for you.
Hope this helped! Please rate my solution!
- Frankie
May 06, 2011 | Panasonic 2.4GHz Digital Cordless...
CRACKLES ALL THE TIME ON ALL THREE PHONES , NO NOISE ON THE CORDED PHONE I HAVE
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones
Jan 17, 2011 | Panasonic KX-TG6311S 1.9 GHz 1-Line...
CORDLESS PHONE HANDSET CREATES NOISE,POWER INDICATOR GLOWS DEEMS
make sure the base is not near strong power supply and comfirm what is feeding the cordless is not noisy too.
Jan 25, 2010 | Panasonic KX-TG5632 Phone
Phone is not working right
move the base / handset away from electrical devices. they are causing RFI (Radio Frequency Interference). good luck!
Feb 08, 2009 | Panasonic KX-TG1033S Cordless Phone
I am getting noise on my cordless phone handset, the other party cannot hear it but then I have a hard time hearing what they are saying, I do not have DSL, and have tried a normal phone in the same socket...
I am getting noise on my cordless phone handset, the other party CAN hear it we have a hard time hearing what is being said. Other phones in the home work fine.
Apr 22, 2008 | Panasonic Lands Phones
Lands Phones Logo
167 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
