Question about Nokia 2690 Cell Phone
How to remove desktop time - Nokia 2690 Cell Phone
Dell Precision T1500 beeping 6 times and will not boot up.
Remove whatever USB cables in the front USB ports below the DVD. Then try starting it should work. If not remove USB from the rear one at a time. Once it restarts replace USB cables into ports.
Mar 11, 2013 | Dell Dimension 3100 PC Desktop
Hp elightbook caps lock and num lock one blink 5 times
PROBLEM WITH BIOS
REMOVE CMOS BATTERY IF IT VISIBLE
AND REMOVE LAPTOP BATTERY ALSO
DONT CONNECT POWER
PRESS AND HOLD POWER BUTTON FOR 30 SEC
THE POWER IN BORD WILL ZERO
AND JUST CONNECT POWER WITHOUT BATTERY CHECK
IF NOT HAPPEN TRY 4-5 TIMES
Dec 04, 2012 | HEWLETT-PACKARD ELITEBOOK 2530P BUSINESS...
Lenovo core2 desktop computer no post no display errors
Remove the ram memory one at a time and try powering up, next remove the video card if you have a plug in type. Disconnect hardware one at a time in attempt to power up, if no change the motherboard will need to be replaced.
Jun 10, 2012 | Lenovo ThinkCentre M55 Desktop Core 2 Duo...
Tuv 4x beepcodes
More than likely a hardware module went bad on your machine. The easiest way to figure is remove the memory modules one by one each time boot machine up with devices removing them one at a time if it stops beeping and loads that is the device that you will need to replace. John
Apr 14, 2012 | eMachines W4685 PC Desktop
Want to add memory to desktop but removing chip is a problem
Yes; I have had some difficulties in finding and changing RAM sticks from time to time. It may sound cruel; but if this is a step you aren't comfortable with, I would pay the tech to do the install. Some places even have a value in the used RAM.
Mar 17, 2012 | E-Machines Computers & Internet
Will not power up
You may need to replace the CMOS battery in your desktop but first:-
  • Check the power connections.
  • Disconnect power to the desktop.
  • Remove and re-fix the hard disk.
  • Remove the CMOS battery and connect power without it.
  • Now power it up.
  • Your desktop may run without the CMOS battery,[untill you replace] but you will be forced to re-set the date and time everytime you start it.
Hope this helps.Thanks!
Please rate this free answer.
Oct 18, 2011 | Acer Aspireā„¢ T180 PC Desktop
The date and time and boot sequence in bios are missing ecah time i turn on desktop.i suspected the internal battery so replaced it .now all i get is blank screen when i switch on "no video...
please remove the memory card and clean the contact point of an eraser then put it back again, also if you are not using the onboard graphic adapter remove also the video card and clean it also with eraser then put it back again and power it.
Aug 01, 2011 | Dell OptiPlex GX280 PC Desktop
How do i remove panel to install memory on dell 3000
Countryboy,
On most DELL desktops, there is a button on the top and bottom. If you push those at the same time it releases the catch holding the case together. When they are released the case will fold open, there is no removable panel. it is a hinged mechanism.
Hope this helps you out
Dave
Nov 21, 2008 | Dell Dimension 3000 PC Desktop
Nokia 2690 Cell Phone Logo
104 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
