Question about Technics SL-MC7 110-Disc CD Changer
Need some help with the cable and spring
TECHNICS SL-MC7 thin cable behind cds
a cable that has a small spring at the end of it came off a little pulley. I noticed it loose when I opened the case. where does it go?
  • WillyWilly Feb 04, 2009
    I have the same problem, and when I turn the CD player on the only thing I can read on the screen is ( C F-26 ) . Coul someone help us with this please?.
Posted on Feb 27, 2009
The cd changer buttons do not work
Could be a broken drive belt. Sounds like the same symptoms that mine exhibited. You will need to open it up carefully, so you don't dislodge any CDs. See previous posts here for the exact size o-ring that you can find at your local hardware store as a replacement.
Aug 03, 2014 | Technics SL-MC7 110-Disc CD Changer
There is a thin wire cable with a spring inside unit witch is the cable is broken where do i get a new one
FOrn get it, PEople are trowing them out, Where i live , Ones that work no one want them any more,
Nov 26, 2012 | Technics SL-MC7 110-Disc CD Changer
My Technics SL-MC7 was zapped by a power surge. I am looking for a power supply. The part number on the PS is CMKS-P3X but when I search it I get hits for a copier PS that does not look like the one I...
You will need a service manual to get the correct part number. Go online to Technics, contact customer support and technical department to see if they can provide one.
Apr 07, 2012 | Technics SL-MC7 110-Disc CD Changer
Hello My SL-MC7 gives a error message No Disk even the tray is full with disks. The disks are taken out to the player and put back again without being played Kind regards Rene
Well the first thing to try is a cd lense cleaner. You may have a build up of prticles and oil on the lense causing it not to read. Secondly, make sure you try a "Shop Purchased" cd to make sure it's not haveing problems reading "cdrs" (home made cds).
If after both of these methods you still have the same problem, it's down to the laser. Could be a series of things from tracking, focussing or the laser has died altogether. Unles your experienced with electronics in a big ay and have test meters and an oscilloscope, you need to decide how much you want to keep this CD player as a new one could be cheaper than a repair.
Jan 06, 2011 | Technics SL-MC7 110-Disc CD Changer
Small cable with spring attached not attached to unit
The cable does run acroos those 4 rollers on the CD drive unit. The cable is staticly attached on the right side (unit facing you) of the carrier rack, routes under the lower rifght roller, up and outside of the top right roller, across and outside the top left roller, then down and inside the lower left roller.
From there, it routes across the carrier to a small hook (black plastic). Under that hook and then up to the spring.
I can send pictures if you need them. I have this same unit with a carrier that will not fully eject the CDs. I have been in this case more than once.
Sep 29, 2008 | Technics SL-MC4 61-Disc CD Changer
Technics SL-MC7 / Can't play cd's any more!
Friend. Did you try a CD that you purchased from the store? if so and this problem persist, then you need to get you a new player. If the CDs are scratched, some players will not play them, If they are burnt in mp3 format, (or data format) your player may not recognised this also. Please try playig a regular CD that you bought from the store, if this work, then you will need to reburn your music as a regular CD, hoping that the SL-MC700. reads copied. It should. But please checks these steps.
Please let me know what works.
Thank you
Dec 08, 2007 | Technics SL-MC700 110-Disc CD Changer
Technics SL-MC7 110-Disc CD Changer Logo
282 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
