Question about Casio FX-9750GPlus Calculator
How to i change it the decimal setting , because i am getting wrong answers
  • Casio Master
  • 8,023 Answers
I am not sure what you are exactly asking. However if you are concerned about the calculator not showing you enough decimal digits, this can be fixed as follows.
  1. Turn calculator ON
  2. If you see no icons, press [MENU]
  3. Use arrow keys to highlight [RUN] icon and press [EXE].
  4. In RUN screen press [SHIFT][MENU] to access (SetUp)
  5. Use down arrow key to scroll down the list of options until you reach Display.
When the Display line is highlighted you can press the function keys
  • F1 to activate Fix display mode
  • F2 to activate Scientific mode
  • F3 to activate Normal (Norm2 or Norm2 ) mode or F4 to activate the Engineering mode
If you select Fix or Sci you will have to specify the number of digits that are kept in the decimal part. You do so by pressing the relevant function key (F1,F2,F3 etc.).
Press [EXIT] to exit the SetUp screen.
Posted on Nov 16, 2010
I don't know if maybe my calculator has a function turned on that rounds the answer to a whole number? But here is an example: 106 x 6.32 = 670 according to my calculator, which is wrong. The real answer...
Your calculator is set to display no digits after the decimal point. To change this, you have two options: press 2nd [SCI/ENG] then select "FLO" for floating decimal or press 2nd [FIX] then select the desired number of digits after the decimal point (or F for floating).
Feb 14, 2014 | Texas Instruments TI 30XIIS Scientific...
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
I want to get an answer in decimal form but it only gives me them in fraction form. What should I do in order to change the settings to give me answers in decimal form?
To convert a single result to decimal, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Nov 14, 2010 | Casio FX-115ES Scientific Calculator
My answers always come in fractions by default. how do i change the settings so they come in decimal points by default? further. how do i change the settings to have the answer in decimal points up to 4...
Press SHIFT MODE 2 to select the LineIO mode. To select the number of displayed digits in fixed decimal notation, press SHIFT MODE 6 and select the desired number of digits.
Oct 21, 2010 | Casio fx-300ES Calculator
Answers in wrong format ?
Did you set your calculator's format in to a fraction? If you did, change the calculator's format in to decimal.
May 10, 2010 | Casio FX-300MS Calculator
How do you change modes so that your answers will be in decimal from not fraction
[2nd F] [Set up] 2 1 will solve the fraction problem. Must be in line mode not write mode to view decimals.
Jan 22, 2010 | Sharp EL-531VB Calculator
TI-89 decimal to fraction
Here is what you do:
1) Press the Mode button.
2) Scroll down the list that appears until you find "Exact/Approx".
3) Change the setting for "Exact/Approx" to Exact.
4) Press enter to save the settings change.
You have three possible settings for "Exact/Approx":
1) Auto - The calculator will try to determine the best format.
2) Exact - The calculator will always give the answer in fraction form.
3) Approximate - The calculator will always give the answer in decimal form.
Nov 15, 2009 | Texas Instruments TI-89 Calculator
How do I change the settings to get my answers in
if you hit the diamond key before enter you will always get your solution as a decimal
Sep 08, 2009 | Texas Instruments TI-89 Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Hello
You need to change a setting in the mode menu.
Change exact/approx to approximate and your answer will be given in decimal.
Jun 12, 2008 | Texas Instruments TI-89 Calculator
Casio FX-9750GPlus Calculator Logo
70 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
