Question about Imation (23780) 320 GB USB 20 Hard Drive
My imation 320 gb 2.5 inch external hard disk cannot readby my laptop, but when i try it in some laptop my external is working there
    Brigadier General:
  • 10,406 Answers
Either the USB ports on your computer are not working
(try some other USB device in those ports to disprove this)
or the USB ports are supplying insufficient voltage/amperage to your Imation device,
such that it does not operate.
Posted on Nov 13, 2010
How to remove the hdd from the imation h100
Use a hammer to crack-open the case.
Not too much force -- just enough to crack it.
Then, you can use tin-snips to cut-away the case.
Jan 14, 2014 | Imation Defender H100 320 Gb External Usb...
Sir/mam my imation external hard disk 320 gb is not detecting in any of my and my friend systems, i tried in windows xp/7, ubuntu. but not working. blue light(power light ) is glowing, while placing...
Unfortunately, external hard drives go bad. A 320 is probably a few years old, I replace mine about every 3 years to be sure. I know it sounds funny, but things work till they don't. Just because it was working yesterday does not mean it will work today. It is possible there is a setting in your XP or 7 to keep from seeing the drive, but doubtful it changed on both systems between yesterday and today.
Oct 30, 2017 | Imation (23780) 320 GB USB 20 Hard Drive
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
I cant seem to use my 320 gb mobile hard drive. when i connect it to the usb, my laptop reads it but i cant save files into it..help me please.
try to connect your device into your pc and then, try to save files again, if this doesnt work, try to reformat your hard drive, im sorry to say that all your previous files will be deleted upon the format. after this, make partitions to hard drive. then save some of your files into it. if that doesn't work either, try a disk scan to check if your hard drive has bad sectors.
Nov 01, 2010 | Western Digital Elements powered by WD 320...
Internal 320 hard drive into external
If you got a USB casing for that, it would have come with a USB and power cable. Yes, power too!
Plug the power, and make sure you have a USB 2.0 hi-speed port. Also check "computer management" and check the hard disk works.
May 24, 2010 | Western Digital (WD3200JS) 320 GB Hard...
HARD DISK NOT RECOGNISED BY MY LAPTOP
try with changing the data cable and the power connector.
Have a nice day and do not forget to rate please...!
Apr 12, 2010 | Western Digital Elements powered by WD 320...
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Apr 06, 2010 | Western Digital Elements powered by WD 320...
The computer no longer sees my 320 gb hard drive, do i need to download new drivers? if ao where do i find them. i store all my photo's and music on this hard drive
Possibilities:
1. dead USB port on your computer -- try another port
2. try a different USB cable
3. try your external drive on some other computer, to see if it works at all
4. open the casing, and separate the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive, thus bypassing that adapter, to see if the adapter has failed, or if the disk-drive itself has failed
5. Google-search for a commercial "data recovery service" -- such companies can disassemble your disk-drive, and fix it, just long-enough to copy all your photos/music onto a brand-new disk-drive.
Jan 25, 2010 | SimpleTech 320GB SimpleDrive External by...
Black
Try to go through disk management and see if it works?
Open control panel then select administrative tools then disk management. Then in left column click disk management.
If you locate it may be it must be initialise by the system or need to create partition by formatting.
You can also check all the cables , the power cables the adapter , try to change the Usb cable also..
ok
Good luck !!
Jan 22, 2010 | SimpleTech 320GB SimpleDrive External by...
WD external Hard drive 320 GB hangs my computer everytime connect
Try the external hard-drive in some other computer.
If it still causes problems, then it is the external hard-drive, not your laptop, that has the problem.
If the warranty on the external hard-drive is still valid,
exercise the warranty to get a replacement.
If the warranty has expired, you could try to "disassemble" the casing, to remove the "internal" hard-drive that is "inside" the casing.
Then, connect that hard-drive to a desktop computer,
and copy your data to the 'C:' drive (or burn your data to CD/DVD disks), if you can -- it's possible that the "electronics" that convert the USB-interface to the hard-drive interface is the problem, and that your data on the hard-drive is perfectly OK.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
Imation (23780) 320 GB USB 20 Hard Drive Logo
389 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
carey w mason
carey w mason
Jax Planet
Jax Planet
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
