3 flashing led
Its a panasonic tx 47p950a rear projection tv
  • 4,234 Answers
That model number does not come up as valid for me. Is this set in Europe?
Dan
Posted on Jun 18, 2008
Panasonic tx-48cx400b TV turns off when I connect my Ps4 through hdmi cable. Can anyone help?
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Dec 26, 2015 | Panasonic Televison & Video
I hear a noise in the back of my Panasonic PT-43LC14
COUNT THE NUMBER OF FLASHES AND CONTACT PANASONIC TECH SUPPORT
Feb 03, 2014 | Panasonic PT-43LC14 43" Rear Projection...
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Projection HDTV won't power up, red LED flashes in front
i am having same problem. 3 flashes indicate convergence problem according to auto diagnostics that you are seeing(info from service manual).
i am starting by replacing stk392-110 convergence amp ic($6 at electronic.com). just ordered them, will let you know how it goes. please check this site-- http://biobug.org/ht/panasonic/ -- very good step-by-step on procedure.
will need service manual afterward. email me if you want copy.
good luck and godspeed,
bridgeman001
Apr 17, 2009 | Panasonic PT-53WX52 53" Rear Projection...
TV WONT TURN ON, STAND BY LIGHT FLASHING 3 TIMES CONTINUOUSLY
i have a toshiba dlp doing that after research i found it to need a lamp replacement
Feb 01, 2009 | Toshiba TheaterWide 46HM84 46" Rear...
Broken screen
Parts Dist Cititronics / Panason St Louis Mo
1 800 846 2484.
please give me a rating for this info.
thanks
daniel.
Jan 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence problems? 3 flashing led
Thanks for the update. Unfortunately, I don't have access to Australian models here in the US.
Check the following (generic troubleshooting)
1) Check the Horizontal Output Transistor for a shorted condition
2) Check the main board for poor solder connections and resolder as necessary.
3) Check the area of the convergence IC for pico fuses and be sure that they are OK. There may be low valued resistors there rather than fuses.
Keep us posted.
Dan
Jun 18, 2008 | Televison & Video
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
