Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
E510 can not start,only the green light on motherboard is good.
  • 70 Answers
TRY TO OPEN THE COVER OF THE DESKTOP KEEPIT OFF WHEN DOING IT BE OVERCAREFUL TRY TO REMOVE THE MEMORY CIRCUIT CLEAN IT PROPERLY THEN TRY TO FIT IT THEN ON THE PC IF IT GET ON ITS FINE OTHERWISE THERE WOULD BE A SYSTEMBOARD PROBLEM CALL A TECHINICAN
Posted on Nov 13, 2010
Dell E510 Diagnostic light 1 is blinking, 2 is out, and 3 & 4 are solid green
those are diagnostic lights which tell a dell tech how to analyze the condition of the motherboard if all four lights are on that indicates a failure more which usually suggest cpu replacement
is your computer doing something odd?
May 24, 2012 | Dell Dimension™ E510 PC Desktop
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
Apr 13, 2012 | Dell Dimension E510 PC Desktop
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
My Dell E510 desktop won't start. No lights on the front
You have problem with motherboard if you’re PC in warranty then call them from u buy your PC.
And Thanks.
Apr 08, 2010 | Dell Dimension E510 PC Desktop
Computer will not start.
Hi friend.
I think your power system not working properly so you need you check your power. if power is ok...then check your RAM Should be connected my motherboard. then your problem not resolve ...you need to contact any computer hardware Eng. they will check it
Dec 19, 2009 | Dell Dimension E510 PC Desktop
Dell Dimension E510 will not turn on
It could be.
When you switch on after it has been turned off for a while look at the fan on the PSU as you switch on.
If it spins or tries to spin for a very short time then I would indeed suspect the psu.
If however the psu fan does spin for longer and you can hear any beeps then that would be an indication of a different problem.
Should that be the case then check here.
http://www.computerhope.com/beep.htm
or here
http://www.pchell.com/hardware/beepcodes.shtml
  • If you found this information useful please click
Aug 13, 2009 | Dell Dimension E510 PC Desktop
I have dell dimension e510 and i got a steady amber and the 2-3-4 are lit up green. i cant get comp to start up what is up with my comp
see if this will open for you
http://support.dell.com/support/edocs/systems/dim5150/en/sm/tshoot1.htm#wp1114195
look for the
Diagnostic Lights that should give you an idea whats going on
Jun 27, 2009 | Dell Dimension™ E510 PC Desktop
Fuji finepix e510 won't turn on
See my possible solution at the posting by kawbene of Jan, 18, 2009 which starts out "Fiji finepix e510 won't turn on... Good luck.
Jan 15, 2009 | Fuji FinePix E510 Digital Camera
Boot up problem
Unplug all the Harddrives, Cd Drives attached to the motherborad. Try turning up the system. If it boots, you may to have to change the I/O cables.
Still if it is amber, then your motherboard is having the problem with. As long as the LED glows PCU gotta be okay.
Kindly get back for futher help
Jan 09, 2009 | Dell Dimension E510 PC Desktop
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
