Question about Honeywell Heating & Cooling
How do i wire this thermo up right, it a tr-010x the orange light keeps flicking and the heating does not stay on
2 Suggested Answers
SOURCE: ORANGE LIGHT FLICKING CONTINIOUSLY
WE CONTACTED OKI AND THE TECHNICAL DIVISION HELPED US
Posted on Mar 19, 2009
Why does my water heat keeps going out if a put a new thermo coupler
That guy at home depot was not completely correct. If the pilot is not keeping the thermocouple warm, the pilot will not stay lit. Figure out why the cycle is being broken or call in a service tech to fix the unit. water heater
Feb 15, 2015 | Water Water Heaters
Tip
Gas Hot Water Tank Not Producing Hot Water Pilot will not stay lit Trying to...
Trying to light your pilot light and it keeps going out when you turn on you gas valve. This is a common problem when your thermo-couple goes out. The thermo-couple sends a small electrical charge to the gas valve to keep its self lit. When the unit calls for heat the pilot flame gets bigger producing more electric and tells the gas valve to open the main gas valve to the burner tubes. The thermo-couple is an easy item to change most of the time. You will need to follow these steps to change out your thermo-couple:
1. Turn off the gas (there is an inline shut off on the supply line before it reaches the gas valve, you need to turn this crossways to the pipe)
2. Locate the thermo-couple it will look like this and be attached to the gas valve
3. Unscrew the thermo-couple from the gas valve
4. Remove the other end of the thermo-couple from the pilot holder
5. Measure or take the old thermo-couple to the hardware or appliance store with you to get the proper length (there are many different lengths of thermo-couples)
6. Reinstall the bulb end at the pilot
7. Reinstall the threaded end on the Gas Valve (make sure not to cross thread the thermo-couple it should start by hand)
8. Turn the gas valve to the pilot position and hold down the red button wait a few seconds then turn off and do again (you will need to do this around 5 times in order to get the gas back up to the pilot light then try and light the pilot)
9. Try to ignite the pilot light.
10. Once you get the pilot light lit you will want to hold down the button for 60 seconds then turn the gas valve to the on position.
Here is an image of a thermo-couple (they will all look similar to this):
Thank you for choosing FixYa.com. If you have any further questions please post them and we will gladly answer them
Justin
on May 03, 2011 | Plumbing
Propane heater not heating
-Thermo is not working. Replace new thermo.
Good Luck
Mai
Dec 04, 2014 | Heating & Cooling
My water heater (model # PTG-74PVP-2) keeps shutting off and flashing C7 76. If I turn it off and back on it will stay on for a little while and then shuts its self back off.
Does your Water Heater have a pilot to light the main flame?
Here is what I usually send to those with Pilot lights, and Thermo Couple problems:
One possibility is that the Thermo Couple is beginning to fail'
What is a Thermo Couple? (TC)
The Thermo Couple (TC) is a small Rod-shaped device with a couple wires coming out the bottom.
The TC actually generates a small electrical current from the heat of the Pilot.
This electrical current is sensed by the control board, or the Main Gas Valve.
As long as there is a pilot, it is safe for the Main gas valve to open, and admit the large amount of gas into the heating burner.
Now-- What helps this TC work the best?
It needs to be just at the edge of the pilot flame--- Not too much in the flame, or the resulting poor combustion of the pilot flame, results in soot forming on the TC-- which insulated the TC from sufficient heat.
Obviously the TC has to be clean (of soot) in order to receive enough heat, to generate the needed voltage to tell the valve that it is safe to open.
And age does deteriorate the TC-- some last a few years, but that is about the end of life for most.
Replacing requires getting down where the TC is, and with a screw driver (usually)-- lossening the bracket that holds the TC. Pay attention to where the wires are routed, and any polarity indicated on the old wires, and duplicate on the new one. Duplicate routing, and polarity, and position the new TC at the edge of the pilot flame.
Pilot flame is maintained by pushing some over ride button-- for a minute or two, until when you begin to release the button, you can feel that the voltage generated by the TC is now holding the pilot valve open, instead of your pressure on the 'start' button.
Any further Questions, let us know..
MackB
Jan 17, 2011 | Rheem Water Heaters
Glo warm ventless heater will not stay lit more than a few seconds burner not pilot lite
this happens yearly..usually it is the thermos couple needs cleaning..this year the pilot orfice itself was dirty and throwing a weak orange flame that was not even touching the thermo couple..I just gave the orfice a good cleaning and now the flame reached out as a long BLUE flame touching the thermo couple and it stayed lit on the first try
Dec 02, 2010 | Desa International Blower Glow Warm Wall...
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My grill lights, but won't really heat up. I
try cleaning the burner and the orffice , check reg is giving right pressure
May 10, 2010 | Thermos Gas Grill 4617222
Mar 18, 2009 | OKI Office Equipment & Supplies
Blower stays on with new themostat
Check to see if there is a short between the green wire and the red wire. Green is the fan control wire for AC. Sounds like some wires may be touching. How did the old t-stat get fried?
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Temperature flux
may be your regolator not working properly. to check it u can use another applience or change it.
Hamid
Aug 11, 2008 | Imperial IFS40 Deep Fryer
Heating & Cooling Logo
89 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
