Question about Fuji Rod Repair Kit
When i turn my camera on it says protected card and cannot take pictures
  • 3 Answers
The card is locked, usually found on the left hand side of card, push the yellow lock key forward to release lock, reinsert in camera, switch on and you should find no further problem.
Posted on Dec 06, 2010
I want to delete protected pictures
If the picture on the camera is protected, unprotect the picture first. In playback mode, scroll to the protected picture, then press the AE-L/AF-L button on the back of the camera.
If the memory card is protected, take the card out of the camera. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 20, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
Screen says "Memory Card Protected" and will not take pictures.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2012 | Fujifilm FinePix C10 3x Optical Zoom, 10...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
The memory card is protected and I am unable to turn off the card protection. unable to take pictures with protection on or download pictures
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 07, 2010 | Panasonic Lumix DMC-FZ5 Digital Camera
Unable to turn off the card protection. unable to take pictures with protection on or download pictures
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 07, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Card write protected
Check if the card is truly write protected (check the little slider on the SD card). Its possible it slid into lock position accidentally
Nov 25, 2009 | Canon EOS 450D Digital Camera
Fujifilem Z20fd I cant turn the card protection off which appears
Is your flash working? Do you have the flash turned on?
Jul 11, 2009 | Fuji Finepix Z20fd Digital Camera
Protected card pops up and i can't take or delete any pictures, but i can look through the pictures.
remove the card. there is usually a switch on the side. turn it to the other position.
Apr 19, 2009 | Kodak EasyShare V1073 Digital Camera
Card protection on wii not take pictures
I assume you mean the card protection on the SD card??? Turn off the camera, pop out the SD card, slide the little switch on the side of the SD card from locked to unlocked, re-insert the card the way it came out, and turn the camera back on. If it still doesn't work, take thed batteries out, reinsert them, then turn it on again. It should be ready now to record onto the external memory. If it still doesn't, get the manual out and check on transferring fiels from internal to external memory.
Feb 27, 2009 | Polaroid T730 Digital Camera
Fuji Rod Repair Kit Logo
42 people viewed this question
Top Fuji Sport & Outdoor - Others Experts
Mark Gough
Rick
Baz Hawkeye
Level 1 Expert
Are you a Fuji Sport and Outdoor - Other Expert? Answer questions, earn points and help others
