Question about Makita 10" Dual Bevel Sliding Compound Miter Saw
One of my apprent's took the blade guard off my saw and it's now in pieces. I've tired to put it back together but no love! My saw is Makita LS1214. Please provide instructions on how the parts go back together.
    Novelist:
  • 178 Answers
Http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=469
Here is a link for your parts diagram and owners manual.
I hope this helps!
Posted on Nov 24, 2010
What is the spring for in the 2000w makita circular saw
Other than carbon brush springs, the only other spring that I know of on a circular saw is for the blade guard so that it will automatically return to cover the blade after you make the cut. There should be a hook or a bend in each end of the spring and each end has a certain spot where it hooks so that it pulls the blade guard back in place.
Jul 13, 2014 | Makita Saws
How to replace a makita circular saw guard
Simple, unpug tool. Remove blade and back flange. Remove circlip and lift off guard. Unclip spring. Re-fit new guard. Refit spring and circlip. Refit blade.
Aug 18, 2013 | Makita Saws
Makita
I don't have this particular model in my shop right now but almost all circular saws work like this. From the blade side of the saw, the spring attaches to a hole in the blade guard usually around the two to three o'clock position. With the blade guard correctly positioned on the saw, wrap the spring clockwise around the bottom of the hub and back up the nine o'clock side. There is another hole or tab inside the top of the upper blade guard somewhere around the twelve to two o'clock position. Hook the end of the spring there and test the guard for free movement throughout it's range of motion.
Aug 06, 2012 | Makita Bare-Tool BSS610Z 18-Volt LXT...
Saw cuts bevel at 0 degree setting. Needs to set to about 3 degrees for square cut. Multiple saws with this problem. Is something bent, or worn out?
Check that the bed of the saw (the flat metal part on the bottom) isn't bent. I've had this sort of thing happen on a jigsaw that needed to be tapped back into square. Check the squareness of the saw with a framing square or a carpenter's square held against the blade and the bed of the saw with the blade guard open. Obviously, make sure the saw is unplugged before doing this.
Jul 28, 2011 | Makita Circular Saw - 15 Amp, 7 1/4in....
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
The return spring for the blade guard on my Makita 5630D cordless circular saw came off. It is attached to the blade guard, but I can't figure out where it attaches to the saw housing. Any hlep would be...
there should be a hole in the housing towards the back of the saw, you can go to Makitatools.com and download a breakdown for this tool.
Feb 01, 2010 | Makita Saws
The spring for the blade cover has come off how do you fix it? my dad has given me his saw to fix the spring that brings the blade safety cover around, how do you fix it the the mounting post. When I do...
if it a Makita saw it will rub on the guard slightly, What is the model number or you can go to Makitatools.com and type in your model number to see a breakdown for this tool. The post is on the back side of the upper guard and there is a hole in the guard itself for the other end.
Oct 03, 2009 | Makita Saws
Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
Jul 06, 2009 | Makita 10" Dual Bevel Sliding Compound...
I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Apr 10, 2009 | Makita 10" Miter Saw LS1030N
Makita 10" Dual Bevel Sliding Compound Miter Saw Logo
147 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
