Dear sir hello,I have a washing machine siemens plus 3101 typ.M31015000 the problem is that the machine has problem with the CPU board can you tell me please if you send me the circuit diagram off the Brain doard it possible to fix it ? Thank you i will wait for the answer .
Bgillespie
  • 89 Answers
SOURCE: cracked discharge hose on GE washer
Are you sure thats the model number? Im having trouble finding it on my end???
Posted on Dec 17, 2007
aborcass
  • 2651 Answers
SOURCE: Washing Machine Smell and Stopped Working
thatss what it sounds like to me the motor simply turned off on overload( giving that electrical, almost burnt rubber smell.) either that or it was overloaded as well as overworked. i wouldnt see any reason for concern, unless was happenig on regular basis
Posted on Apr 05, 2008
SOURCE: washing machine circuit diagram requested
you all need help
Posted on May 18, 2009
  • 53 Answers
SOURCE: Hello-My Beko washing machine (WMA 1512 W)does not
recheck the brushes & pump/filter/outlet hose (make sure all cleaned out and impeller free to turn) your problem lies in there somewhere.
Posted on Oct 21, 2009
Testimonial: "Hello -The brushes have about 10mm left but will re-check ,the pump works well, I suspect the speed module board Regards Andyrooshous"
jsrock516
  • 5911 Answers
SOURCE: Hello!
If the washer fills normally, begins the wash cycle, then stops at the spin cycle and won't drain, then you need to check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Jun 10, 2010
Have any idea how to open the washing machine door iQ700 Siemens
Wait for cycle to fi?ish, plus another minute or so. Then activate door release. If this fails I suggest that you have the machine looked at by a technician.
Jul 16, 2015 | Siemens Washing Machines
Cold Fill Siemens Does Not Get Hot
yes this could be the heating element or thermostat
May 29, 2013 | Amana ALW880WH Top Load Washer
Siemens siwamat 6140
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTMUse the link, you will need to enter the Enr number which is on the rating plate and should start W...
Nov 22, 2011 | Siemens WDi1640 Front Load Washer / Dryer
What does error code f67 on a siemens wash machine mean?
I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
Apr 18, 2011 | Bosch Washing Machines
WFXD8400 UC Washing Machine motor is not working now.
This means one of two things. The motor is bad or the control has failed. You can test this with a volt meter to confirm.
On these units the board normally causes this issue. I like to check voltage at the motor to make sure.
http://www.appliancerepairlesson.com/
Mar 11, 2011 | Siemens WFXD8400UC Front Load Washer
Wash comes out wet on highest spin speed. The drum spin speed doesn't appear to be fast enough. Is there an adjustment for the spin speed?
Hello, the trouble here is with the spin control board. To confirm this pop the top off and get the tech sheet from inside the machine. next run the diagnostic cycle using the instructions on the sheet. this should confirm the spin control board is bad(sometimes called the motor control board) Hope this helps! Mike
Nov 03, 2009 | Siemens WFXD8400UC Front Load Washer
Need control board wiring diagram donot know where all the wires plug in
Hello, my name is Nikos and i have o problem with my washing machine. Thiw is a siemens siwamamat xl 540 and the problem is the control board. I try to find and i can't.47c967f.jpg
Sep 21, 2009 | Washing Machines
E 803 when machine is turned on
Hello sir;The error code you display including so many mesnings; transfer unit level switch, left front interlock switch, DC power supply, DC fuser board, DC driver board, CPU board, DC power cut relay.
My suggestion go to check al those switch first if still don't work then go to others.
Jul 18, 2009 | Canon CLC 1120 Color Copier
Wash programme will not start
Start button is bad, the button it self, not the board
Jan 03, 2009 | Siemens WFXD8400UC Front Load Washer
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
