Question about JVC KD-S680 CD Player
JVC KD -S680 needs help
Ok I have a big system in my car.. everything has been working fine.. until Sunday... I went and turned on the car and the stereo receiver face plate was warm but everything else in the car was cold... *weird right* well i tried to turn on the radio, nothing, so i took off the face plate and checked it, nothing wrong with it.. put it back on, the face plate *the buttons not the display* all light up.. but you still cant rurn on the power, eject the cd or anything.. Took off the face plate again, cleanred the lil connectors and put it back on, once again, the face plate lights up, but nothing happens, no power no nothing... so i turned on the car the lil button you push to turn on the power automatically lights up, but still no power, no nothing.. .... Do you know what would cause the radio to all of a sudden just die out of no where... Is it time for the white flag for this radio and just time to get another or can it be fixed? My player just died. There is not life at all, my first check was to see if a fuse had blown but that is not the case. Unit worked fine one day and the next there was not power signs at all in the unit. I hope I can just replace the face unit but am not sure that this is the real problem, would welcome any suggestions. My email is aquatic@ix.netcom.com
  • 1,183 Answers
Thanks for the description of your problem. At the face of it , it looks like the problem is only the face plate. Coz the unit lights up fine and there are no blown fuses. I recommend replacing the face plate first and checking. If the that not working , we have to open the unit and check internal connections.
Also do check all your relay cables, just to make sure you are getting proper current to the unit.
Thanks
Proton
Posted on Jun 18, 2008
  • JVC Master
  • 13,433 Answers
Maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Not reading cds
first ask your self
has it ever worked?
are these cds burt as mp3 cds and not just plain audio cds?
it might need to have the lense on the laser cleaned other than that its pointless and probably is just bad, the cd player is old
Jul 16, 2010 | JVC KD-S680 CD Player
Cannot set clock on kd-s680
Press and hold SEL for more than 2 seconds. SCM link , CLOCK M , or CLOCK H will appear . "THATS WHAT WAS BUGGIN THE HELL OUT ME "SCM link" ok when you see that on the right press up or down on the ssm button to change it to Clock H and Clock M . Then just adjust the hour and minute with the turn knob that surrounds the SEL button . After set press the SEL button to finish the setting. Have nice day :)
Mar 24, 2009 | JVC KD-S680 CD Player
I don't know which JVC unit I have.
no i dont think so. but it is fairly easy to remove if u visit your nearest store that sell car stereos ask them for the removal too for a jvc radio. they should give u to flat L shaped pieces of metal all u have to do is remove the thin plastic trim piece around the radio then on both sides of the radio between the radio and the metal cage that holds the radio they will slide in u may have to play around with them a little till they unlock the radio but when they do all u have to do is just slide the radio to u enough to read a white label on the top of the radio that will give u the model number. should take no longer than 15 min. after that pull the tools out then just slide it back in till u here or feel it lock and your done oh dont forget to put the radio trim back on.
Nov 13, 2008 | JVC KD-S680 CD Player
Stereo wont pick up any AM channels
I forget my code for my jvc kd g431 can u help me pls
Jul 22, 2008 | JVC KD-G430 CD Player
Car cd changer not working!
try pulling the fuse and resetting it, make shure its the +12v cont wire
Don
Dec 29, 2007 | JVC KD-S680 CD Player
Sound not good
could have blown the speakers or if there sub woofers ran off an amp that might be your problem as far as the cause it could be something as simple as a loose ground or some wire that is getting power grounding out on a piece of metal somewhere i would double check all of your connections
Oct 04, 2007 | JVC KD-G200 CD Player
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
JVC KD-S680 CD Player Logo
174 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
