Question about HP D1560 Deskjet Printer InkJet
My lexmark z22 has never been used, has a new ink cartridge installed, but will only print test pages -- not what i want to save. please help
  • HP Master
  • 32,281 Answers
First you need to connect the printer to your computer with the supplied printer cable including the power cable.
You need to install the printer driver on you computer.
You may need to setup the printer preferences, eg. paper size etc.
You printer is now ready to print your documents. When you have opened an document such as a word document, to print this document click on file - print
Posted on Nov 13, 2010
Lexmark 730 not printing
Regarding the Lex1 cartridge's no printing/severe fade (or similar) during printing, my answers are provided below:
For the poor print quality problem (degraded image quality) you are observing, we suggest you first visit the "Print Quality" page of the "General Information" section of the Inkjet 411 website and follow the suggestions provided: http://inkjet411.com/?page_id=1432
A. 1. Cartridge & Printer maintenance should also be evaluated - ensure both ink cartridges and flexible driver contact cables (where the cartridge interfaces to the carriage inside the printer) are thoroughly clean: http://inkjet411.com/?page_id=1519
A.2. Perform a hot-water flush on the suspect ink cartridge, refer to video procedure here: http://inkjet411.com/?page_id=1519
A.3. Run a quick test print to evaluate cartridge performance (i.e. 4-color test print):
http://inkjet411.com/?page_id=146
For information on North American ink refill services (for Lexmark 1, 2 and 3 ink cartridges) at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced Lexmark printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jul 16, 2013 | Lexmark Office Equipment & Supplies
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Will not print on paper
if the cartridges were out of the printer for any length of time the ink has dried up on the print heads. you most likely will have to replace the ink cartridges. then allign again before it will print correctly
Apr 04, 2010 | Lexmark JetPrinter Z22 Color InkJet
My Lexmark z22 printer will not print corretly
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
Color ink want print after installing new cartridge
have you installed the cartridge correctly??? make sure you did
try to print a few pages, to get the ink going.
try test pages, try the aligning procedures as well.
Mar 26, 2009 | Lexmark Z515M InkJet Printer
Lexmark z640 has stopped printing - goes through the motions but no ink on page
Some third party cartridges will not work with your printer as they are remanufactured from used cartridges.
It is more expensive to buy genuine Lexmark ink, but atleast you know it will work.
You may try reinstalling the driver before buying new ink.
I hope this helps.
Good Luck.
Oct 18, 2008 | Lexmark Z640 InkJet Printer
Not printing very well
I have the same one at home, try using the cleaning mode from the utility menu. That helps out every time you change a cartridge.
Aug 23, 2008 | Lexmark JetPrinter Z22 Color InkJet
Printer not printing
try a test page, first, please..computer disconnected from printer..
and go get fresh set of printer drivers here
Mar 17, 2008 | Lexmark JetPrinter Z22 Color InkJet
HP D1560 Deskjet Printer InkJet Logo
Seeker5211
Seeker5211
