Question about HP Officejet 5610 All-In-One InkJet Printer
After not using printer for several months my printer will not print even after buying new ink cartriages what do i do?
  • HP Master
  • 32,281 Answers
Inkjet printers do not like being left unused.
The print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Posted on Nov 13, 2010
Black ink will not print
You can probably buy a whole new print head. They're expensive, but it might be worth it depending on the replacement cost of the printer. Another option is to get a cleaning fluid cartridge at carrot ink or some other ink website.
I've given up on cleaning, though. Now I use OEM ink and I make sure to print something at least once a week to keep the ink in the head from drying.
Aug 15, 2009 | Epson WorkForce 600 All-In-One InkJet...
Ink shows empty when toner is not even close to empty
there is one thing that if you refill the cartriage and then use again then still ink indicator shows low ink as its' ckt is designed so.
there is no problem you can print easily.
your printer will show correct ink level when you put in new cartriage.
but remember one thing that if your printer stops printing and shows message on computer that no ink in cartriage ,, then you need to reset printer counter, (this resetting process is present in your printer manual)
so no problem in printing, it shows low ink because the circuit inside it is designed soo.
so that you purchase new cartriage.
(remember : you need to reset the counter , refer to manual)
Jul 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Deskjet printer cartridge problem - won't print
I was having the same problem and just posted it, went back to my printer, put the old cartriage back in and printed, I am taking the refilled cartriage back to walgreens where I had it filled and buying a new/hp cartriage to install.
Mar 17, 2009 | HP DeskJet F380 All-In-One Printer
Printer claims black ink cartridge is empty, but it can't be.
Se if the tape, that comes with a new cartriage is of the cartriage if not try a new cartriage if the does not work your machine needs service
Jun 11, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
No ink on page
Clean the contact in the housing area and on the ink cartriage. If that does not work buy a new cartriage. The ink probably dried up in the nozzles. You can place the ink cartriage on a wet paper towel water or alcohal and press the cartriage into the towel. If you see no ing replace.
Jun 11, 2008 | Office Equipment & Supplies
Won't print in black
unplug your printer and reinstall the drivers. Your printer is sending data to your computer saying that you are still out of black ink. By rebooting and also re installing your drivers it will reset its self. Or you can pull your color ink and see if it reconizes the black with out it. There also may be a problem with your black shuttle depending how long you were with out black ink it could of dried the surface that helps extrude ink from the bottom of the ink cartriage. I have found never let a ink cartriage ever run completely dry before you buy a new one.. A little wastefull maybe but it can save you in the long run.
Nov 21, 2007 | Canon i455 InkJet Photo Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
320 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
