Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Yamaha 600vmax snowmobile engine
It has a pull start , no starter and I need to hook a battery up for a lectric fan and the battery wont stayed charge
    Genius:
  • 1,036 Answers
Hi there!
The battery will run down, because there is no means of charging it.
Is an alternator fitted at the moment for lights etc? If so, you will need to measure the voltage from that, then connect to the battery to charge it.
If there isn't one, look for a motorbike alternator that will fit, or contact the manufacturers for a genuine part.
Posted on Jun 18, 2008
What to do when motorcycle will not start tipped over tries to start but wont fire up
How old is the battery? You need to check if the alternator is putting out a charge, is the regulator working. A dead cell in the battery will often show a full charge state if you try to charge it. When you try to start the bike the battery is required to give a high charge to the starter. The buzzing you hear is probably the starter solenoid trying to work. I would suggest fit a new battery and if the bike starts OK check out the charging system. 14.4 volts is the normal reading across the battery with the engine running at 5K.
Jul 18, 2014 | Yamaha YZF-R1 Motorcycles
Changed the battery in my 2006 yamaha r6 now it wont rev up
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r1-forum.com/forums/104-04-06-r1-mechanical-help/323828-battery-charged-bike-still-wont-start.html
http://www.r6-forum.com/forums/57-garage-mechanical-help/153806-2006-r6-wont-start.html
http://www.r6messagenet.com/forums/pdf/2006R6Service.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 06, 2014 | 2006 Yamaha YZF-R6
Replacing starter
The Starter is located forward of the Engine, Left side. Make sure you disconnect the Battery BEFORE you start working on the starter.
Dec 18, 2013 | Yamaha 2005 RS Venture
Yamaha XT660X Starting up problem, need help?
Hi, Mark before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
XT660Z 2010 will not start need help XT660 com The 1 XT660 Resource
Yamaha XT 660X starter problem
YAMAHA XT660R Service Manual
Yamaha XT660R Owner Manual
May 03, 2017 | 2004 Yamaha XT 660 X
Yamaha r1 no neutral light,start button not working, full charge battery
http://www.r6-forum.com/forums/57-garage-mechanical-help/162715-will-not-start-good-battery-no-clicking-but-no-turn-over.html
2000 2001 Yamaha YZF R1 Service Manual R1 Moto Data Project
Jul 31, 2012 | 2000 Yamaha YZF-R1
No electrical power on my 03 yamaha R6 with a brand new fully charged battery
Hi, Brian and the usual suspects are:
http://www.r1-forum.com/forums/102-00-01-r1-mechanical-help/228208-bike-not-starting-no-power-w-new-battery.html
http://www.r6-forum.com/forums/46-general-discussions/143936-i-need-electrical-help-bike-wont-start-new-battery.html
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
May 22, 2012 | Yamaha YZF-R6 Motorcycles
My yamaha radian won't start
Hi, Joseph before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
10. Starter relay, solenoid or starter circuit wiring faulty.
YX600 Radian Not starting
What to do When Your Motorcycle Won Start
Yamaha YX600 Service Manual
http://www.badrad600.com/Radian%20Manuals%20-%20Complete%20-%20Printable/Radian%20Owner's%20Manual%20Clean%20Complete%20Final.pdf
Apr 05, 2012 | 1987 Yamaha YX 600 Radian
I have a 2004 R1.start it and it runs fine. when I ride it more than a few miles and turn it off it wont start like batterys died. l just let it sit for maybe an hour it starts right up. I put on charger...
Hi, Tom and the usual suspects are:
99 R1 won start wondering about the diagnosis
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
Apr 13, 2011 | 2004 Yamaha YZF-R1
STARTER WONT STAY ENGAGED LONG ENOUGH TO START ENGINE - STARTS TO CRANK AND THEN SOUNDS LIKE IT's FREEWHEELING
Almost certainly a discharged battery ( have the battery fully charged ). - If that doesn't solve the problem then check the wiring connections to the starter motor, if they are loose or corroded they can overheat,also resulting in the symptoms you described. Tell me how you get on and Please leave feedback!!!!!
Jan 26, 2010 | 2002 Yamaha V Star Classic
Lands Phones Logo
49 people viewed this question
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
