How to fit the toner cartridge - Office Equipment & Supplies
2 Suggested Answers
SOURCE: printer toner cartridge won't fit
after loading a catridge it is showing " no print catridge ". how to solve this problem?
Posted on Jul 06, 2008
Which toner should I be using in a brother mfc 8730 dn printer. I have just got a new one and I cannot get the printer cartridge to fit in
The old toner cartridge has the model/type printed on the label.
OR
Just order the toner cartridge for your model printer.
Apr 06, 2011 | Brother Office Equipment & Supplies
HOEW DO iCHANGE THE INK CARTRIDGE?
open the front cover. pull the whole toner cartridge out and fit with new one.its a black toner cartridge and it pulls out easily but when you fit new one, push it in slowly until it goes and clips inside, you will hear it when it clips in.close the front cover and it will reset itself.
Jan 06, 2011 | Samsung ML-2510 Laser Printer
How to insert a cartridge in canon printer 4320d ?..
Hold the front side of the operation panel with your hands.
Lift the scanning platform (A) until it is locked. (You will hear an audible "click.")
Hold the grip (A) on the right front side of the toner cover.
Take out the new toner cartridge from the protective bag.
Do not open the drum protective shutter (A).
Save the protective bag. You may need it later when you remove the toner cartridge from the machine.
Gently rock the toner cartridge several times to evenly distribute toner inside.
Place the toner cartridge on a flat surface and pull the seal completely out.
If toner is adhered on the removed seal, be careful that your hands or clothes do not get dirty from touching the toner.
Do not pull the seal out at an angle.
Hold the toner cartridge by its handle (A).
  • Do not open the drum protective shutter on the toner cartridge. Print quality may deteriorate if the drum surface is exposed to light or is damaged.
Always hold the toner cartridge by its handle
Insert the toner cartridge so that the protrusion (A) on the right side of the toner cartridge fits into the guide (B) located on the right side of the machine and slide it down parallel to the guide.
Push the toner cartridge to make sure it is properly set in the machine.
Close the toner cover.
Lower the scanning platform.
If you cannot close the toner cover, do not force it to close. Open the cover and make sure the toner cartridge is properly set in the machine.
Be careful not to get your fingers caught.
Dec 04, 2010 | Canon Office Equipment & Supplies
"009-362 Printer, Restart Printer, Reseat c cart., contact support"
The Cyan Toner Cartridge is either not seated correctly or the cartridge is bad. Open the front of the printer, pull out the Cyan Toner Cartridge, reseat making sure it fits all the way to the back.
If the problem is not resolved replace the Cyan Toner Cartridge.
Oct 21, 2010 | Dell Printers:Dell MFP Color Laser 3115cn
We have been sent a toner cartridge for our ir3300 but despite directions on the side of the box it does not appear to fit
Canon toner type GPR-6, correct? Open the front cover. Rotate lever to release toner/developer unit. Pull the unit straight out until it stops. Insert new cartridge to line up with top of toner/developer unit at a slight angle (lower at back) Once the cartridge stops at the rear (I would hold the toner/developer unit with one hand while inserting the cartridge) then lower the front end of toner cartridge down on top of the unit.....press down until toner cart. clicks into place. You will know because a tab pops out the front with clear plastic attatched. Pull the tab to release toner and release top of toner/dev. unit. Keep pulling until it stops. Wait about 7 seconds, now tap on toner cartridge to release all loose toner (don't forget to shake toner before opening) After about 15 seconds, toner should be fully loaded. Now push top cover of toner/developer unit back in until it latches, you will know because the empty cartridge releases from the unit. Now remove empty cartridge, reinsert unit, turn latch handle and close front cover.
Oct 07, 2009 | Canon Office Equipment & Supplies
Toner cartridge not loading
Cheat the front door interlock and watch the toner bottle to see if it is turning. If not, could be a bad toner drive motor/drive assembly. Otherwise, remove and disassemble the toner hopper and clean it up. Make sure the four clear 'scooper' tabs are attached on the back of the receptacle that fits around the top of the toner bottle. Otherwise, just purchase a new toner hopper, they are cheap.
Sep 15, 2009 | Ricoh Aficio MP 2000 Black and White...
Dell 3110cn toner error message "remove y tape". I have changed the cartridge twice now and cannot get the message to go away. Now after just a few days in the machine the yellow is beginning to fade like...
A new Dell original toner cartridge has a pull tab on one side. This is a seal on the toner hopper and prevents spillage during transit.
Some remanufacturers fit a seal too.
This is not the same as the drum cover (large orage plastic thing on front of cartridge), which you will have removed.
I order for the cartridge to be tested, a small amount of toner is used on top of the seal.
So, it sounds like you haven't pulled the seal, and the "after just a few days yellow fading like empty", fits in with this.
Aug 26, 2009 | Dell 3110cn Laser Printer
The toner cartridge replacement won't fit
Yes it is possible that they did not send you the O.E.M. toner cartridge. Some of the gerneric toners are made for a few different models and they may not fit exactly.
Nov 20, 2008 | Sharp AR-M207E Black and White Copier
Printer toner cartridge won't fit
Jul 04, 2008 | HP Photosmart C6180 All-In-One InkJet...
Print quality on my HP 2420
take out toner cartridge and wipe the compartment where toner cartridge fits with dry a microfiber towel if this doesnt work Replace toner cartridge with a new one somtimes when toner is low it will make lines and dump excess toner
Jan 17, 2008 | HP LaserJet 2420 Printer
16 people viewed this question
k24674
jasbo
jasbo
