Question about Cameras
Gp powerbank manual insructions for batteries charger v800c
HOW DO YOU CHANGE THE BATTERYS
Depends on what battery. car battery I charge with i 10 means with a current 1 / 10 of the capacity in Ampere hours for 14 hours. So a 80 Ah battery with 8 A for 14 hours.
A camera battery in the charger I got with the camera. Or a good universal charger from GP. A NiMH AA or AAA battery, with a quick charger that at least needs 2 hours to charge. The quick chargers I have that can charge in less than 2 hours (one can manage in 15 minutes) all kill batteries after a few charge cycles. Hope this helps.
Mar 15, 2015 | Cameras
My Alante Jr power chair stopped working. when plugged in ,the charger light is green which means a full charge but the led lights all ten of them on arm continuous go from side to side without stopping....
The batteries are too low for the charger to work. You need to take the batteries out and charge them separately with an automotive battery charger. This may take 2 or more days for each battery. When the voltage on the battery gets past 10 volts, you can put them back in the chair and finish the charging with it's charger.
Jan 28, 2015 | Golden Technologies Alante Jr GP-200...
My proscan tablet is saying battery with
meaning the battery is deffective....it cannot be charged..i suggest use a power bank...if you do not want to open your tablet and replace the battery...use powerbank instead. it is quite bulky and heavy, but it is worth using...when buying powerbanks, look for the highest mAh rating..Mah means miliampere hour...or the discharge value...the higher the value, the longer the time the battery is discharged
Oct 15, 2014 | Tablets & eReaders
My tablet wont charge it was purchased nov 2013
the internal battery has reached it's lifespan.....use power bank if you don't want to replace the internal battery..the tab will get the power from the power bank...powerbank is a recharcheable battery with usb connection than can be connected to your tab to power it up....
Polaroid HD digital camcorder dvf 720 .what size or type of charger does it take?
I use one universal charger (GP) for 4 different Photo Camera's and one video camera. All batteries are charged correct. On my charger I need to set the contact points correct for the different batteries, but after I put one on the chatter it becomes charged in a few hours. (I don't need to look for voltage nor for where the plus and minus go.
My advice? Google for universal battery charger for camera's and buy one. I think the charger will serve your next camera too.
May 18, 2014 | Cameras
Need a charger for my camera
Harrie 465 solutions Nov 27, 2013 Category Expert Just google for universal camera battery charger. I do use one, because I do have Nikon, Canon, Kodak and even an Epson digital camera. My charger from GP does them all. The only thing I have to do is place the contact points on a correct place. There are universal chargers you don't have to do anything, but put the battery in.
Nov 26, 2013 | Cameras
Trying to buy a new charger for my camera Eurocyber
I need to replace my charger were I can order?
You can try to buy an original, from the brand of your camera, but there are lots of univeral chargers, that moostely costing less and you can use them to charge batteries from other brand too. I bought a GP Digital Camera / Camcorder Universal Li-ion Charger. On this you still have to put the connection point in the correct position by hand, but there are universal chargers you just put in any battery and it will be charged. Just google for universal Camera charger, or visit your local camera store.
Nov 01, 2013 | Cameras
GP 360 Radio Charger
On a Motorola charger, when the battery is charging the light should be a constant red (or amber depending on the charger). When the charge cycle is complete the light will change to solid green. Sometimes the solid green time is brief, as the battery will begin to lose charge, and the charger will go back into trickle mode and change once again to red (or amber). In most cases, a flashing light indicates a problem, such as a bad or shorted battery, an incorrectly seated battery, dirty battery contacts, or a bad connection with the battery. (Note: Batteries last 18-24 months typically. Check your date code for the age of the battery.)
There were several chargers made for the GP360, including but not limited to a 60-minute charger, a 90-minute charger, a 10-hour trickle charger and a 6-unit gang charger which would be a rapid rate, either 60- or 90- minute. If you would supply your charger's model number we could tell you which one you have.
Nov 02, 2008 | Motorola HNN9628A Two-way Radio Battery
Battery drain
Maybe your using relatively cheap batteries with a low capacity.
I would try GP powerbank batteries or simular with charger with a high capacity like GP 2300. If it still drain quickly there is something wrong with your remote.
Oct 02, 2007 | Logitech Harmony 659 LCD Remote Control
Cameras Logo
243 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
