Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My Epson dx440 just won't print anything i've changed the print cartridges cleaned nozzles and head and when printing the paper is completely black help!!!!!
SOURCE: not printing
You need a new print head
Posted on Jan 18, 2008
  • 3 Answers
SOURCE: Epson Stylus DX8400 empty ink cartridges but actually new
Sometimes there is a coating on the chips (even original epson ones!) - Old wives tales say dont touch the chips with your fingers - but take the carts out one by one and wipe your finger over the chips (1 finger for one chip - dont reuse the same finger on a different chip)
Reinstall them and that worked for me on a dx4500 with original epson carts in
Posted on Dec 29, 2008
  • 140 Answers
SOURCE: epson c62 print head clogged
The first thing is that you need to get some compressed clean air and blow all that mess up. There is compressed clean air that comes in a can kinda like wd-40 with a small straw. You can buy it at Radio Shack or some electronic supply place. That will do the trick. God Bless.
Posted on Jan 12, 2009
  • 2666 Answers
SOURCE: printer will not print in black ink. Epson stylus color 400
Try cleaning the print heads.
Posted on Jun 19, 2009
fisherman816
  • 66 Answers
SOURCE: how to clean head printer nozzles on epson dx4400
maybe this will help...http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41664&prodoid=46253282&infoType=Downloads&platform=Windows
Posted on Nov 08, 2009
How do I stop lines on the epson 4515
Cleaning only helps if there is still ink in the cartridges.
If you print the nozzle check, you can see what colour is having problems to print.
And when you are sure there is still ink in the cartridge, you could try to remove the cartridge, and in the printer, where the cartridge was, you could put a drop of cleaning fluid in the nozzle on the bottom. Then try printing one or two pages on full colour, till the ink starts coming through.
Be aware, sometimes just a bit of dust is traveling wit the print head, blocking the ink too. But then you see smear on the paper.
Always be sure the underside of the print head does not have debris traveling with the head.
Almost impossible to see, but epson sometimes delivers special cleaning paper. It is a pice of paper, with a special pice of sticky tape. Sometimes it comes with the Ultra Glossy Photo Paper. Use it.
Aug 21, 2014 | Epson Office Equipment & Supplies
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
I have not my Epson Stylus Photo for quite some time. Now I want to use it again, I 've put in some new cartridges. The print shows repeating (green) lines. Any idea what could be the problem ?
To help complete the pattern, feed copy papers to the printer and do atleast 40 blank photocopies and afterwards clean the head and check the nozzle.if it has not improved, repeat the same procedure until the pattern completes.mine also had the same problem but after doing that, it was solved for good.
NB: Command copies without putting any printed paper to save ink.
Oct 12, 2012 | Epson Stylus Photo R220 InkJet Printer
Printer worked fine until yesterday changed ink cartridges now black wont work tried all options
Hello
well changing the cartridges will not effect anything to the printer but the duration taken for replacement will. As in epson if you leave the printer without cartridges will clog the head nozzles. Did you remove the cartridges and turned off the printer and left idle for sometime? if yes then follow the instructions below
1. Print nozzle check test print to know which nozzles are not working
2. Head cleaning from the printer software.
3. Perform step 1 again to see the difference after cleaning
IF NO
Then you have to take the print head out of the printer and clean the nozzles by using hot water in the Syringe and blowing the derbies out of the nozzles.
Jul 17, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
I have a Picture mate 100, which I have not used for some while. Just inserted a new cartridge & used "Clean Print Head" function 4 times but still have v poor quality on Black & Yellow....
Hello
1. Use paper recommended by Epson
2. Use genuine Epson ink cartridges
3. Avoid using old or damaged ink cartridges
4. Make sure the printer is on a flat, stable surface
5. Make sure your paper is not curled, damaged, dirty, or too old
6. Make sure the paper type selected in the printer driver is appropriate for the type of paper loaded in the printer.
7. Clear the High Speed checkbox in the printer driver and run the Paper Guide Cleaning utility.
8. If your printer has a lever/paper thickness lever, make sure it is in the paper position.
If printouts are still poor after following the advice above, the issue could be related to the alignment of the print head or caused by a partially blocked print head.
You can check the print head nozzles from your computer by using the Nozzle Check utility. In some cases blurred prints could be caused by blocked nozzles on the print head. Whilst less common, this should be checked to eliminate it as a potential cause.
also recommend that a standalone nozzle check (Self Test) is printed to rule out an issue such as interference from an electromagnetic field, such as that which can be caused by PC speakers.
The printhead alignment could also cause this to happen I also recommend you use the Head Alignment utility, accessible from the Maintenance/Utility section of the printer driver.
Jun 19, 2011 | Epson PictureMate 100 InkJet Photo Printer
On the wifi printer from my computer i can push print and the printer starts pushing the paper though but it wont have any ink or anything on it and it goes though rather to fast the ink is full but it's...
please try these steps:
1. Print the nozzle check - see if the color lines are complete, there shouldn't be any gaps. You should see a couple of black, yellow, red and blue lines.
2. If there are gaps (a few or multiple), do the head cleaning cycle and re-print the nozzle check. Observe for any improvements. If there is improvement, do the head cleaning cycle again and print the nozzle check until all the lines are all complete.
3. If there isn't any improvement, try removing the inks from the printer and put them back in. Then, do the nozzle check again. If that does not work, then the print head nozzles might be clogged. Please contact Epson Technical Support. t
Nov 30, 2010 | Epson WorkForce 600 All-In-One InkJet...
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Nov 12, 2008 | Epson Stylus C66 Inkjet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
140 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
