Question about Hitachi Televison & Video
I pressed the magic focus button, on the TV panel, and now all I get is wavy lines for 30 seconds and then the tv turns itself off
  • randos2 Jun 18, 2008
    The TV is a Hitachi C46-F200 Projection color TV
  • Hitachi Master
  • 8,617 Answers
Your problem most likely is in the digital convergence control unit.
Posted on Jun 18, 2008
How do i adjust the magic focus?
  • Press "Menu" on the remote select the "Magic Focus" option in the Video menu or press the "Magic Focus" button on the front panel to adjust the convergence of the three picture tubes that create the proper color for the picture. Pressing the button on the TV initiates the automatic adjustment, and accessing the feature through the Video menu allows you to choose automatic or manual adjustment, though the "Automatic" setting must be selected for the button on the front of the TV to begin the process.
  • Aug 04, 2011 | Hitachi 53UWX10B 53" Rear Projection...
    Hitachi 43fwx20b Convergence Problems
    These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
    Here are some of the most common problems with these sets...
    Problem #1) Convergence
    Yours may have one or more of the following symptoms
    • Screen Looks 3-D
    • Colors wont align
    • Screen may look distorted or warped
    • No Audio/Video - makes a chirping sound.
    Problem #2
    Another common problem is dull or washed out video.
    Your TV may have one or more of the following symptoms....
    • Dull looking picture
    • White looking picture
    • Halos around objects
    • Red/Orange looking picture
    You can see some more examples and find a fix here
    Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
    Magic focus problem
    in the menu first check if focus is set to auto or manual, need to be auto, if it is then pop off the front cover and acess panel with TV on cafefully press small button on signal pcb front edge, this is service mode, press pip mode,then pip channel after intialize turn TV off then on, function should be restored.
    Aug 09, 2009 | Televison & Video
    Yellow and blue color ruins total picture on 50" tv,can't get rid
    I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
    Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
    Blurred picture
    try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
    Feb 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
    Samsung tv/video panel lock
    if you have a universal remote ( i just used the all for one 4 model )
    1 ) press the vcr button. 2 ) hold the magic button down wait for 2 red flashes. 3 ) enter code 0240. 4 ) press the power button on the remote tv will turn itself off. this will get the panel lock off the tv.
    i have just done this after 30 mins of trying to work out why the panel lock would not come off with trying the tv codes. you have to use the vcr codes. my tv is now working and my grandson can play his playstation again with no problems just had it working.
    dated 13:07:2010 1800pm. hope this helps someone
    Dec 09, 2007 | Televison & Video
    Won't turn off
    Go to the panel (on the tv set), hit magic focus on there....then hold power button for several seconds long. It should go off and fix your problem.
    Jan 22, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
    TV automatically turns magic focus mode on when the power button is pressed on the remote and even manually.
    I have this problem starting today. Unfortunately, others who have fixed it have done the following.
    * Unplug TV for hours and it worked
    * Buying manual switch to the outlet or surge protector and switch power off that way.
    It appears that I'm in no mood to spend hundreds to get this fixed for hundreds of dollars and just going the Radio Shack route of buying a switch which would probably be more of savings. But needless to say, I hope that is the only problem I have.
    Sep 27, 2006 | Hitachi 46F510 46" Projection HDTV
    Televison & Video Logo
    127 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
