Question about Intel D945GCCR Motherboard
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can any say remedy for this problem.
    President:
  • 556 Answers
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
My system is workin properly but the screen - 21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
Text is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start buttonMy system is workin properly but the screen - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.pngages/4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png" alt="4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png" class="h_mi" />, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Posted on Nov 13, 2010
My 87 740 gle, stalls when put in gear and/or off idle. I checked the fuel system, which seems to be ok, Theres fuel at the injectors, and even seems to flood at times. The battery,alternator are good and...
I would address charging system first as a low battery will give all sorts of problems.
Put a mutli meter across battery should read 13.8-14.5v engine idling. Battery MUST be fully charged to do this test though.
What is battery voltage with all switches OFF. Should be above 12.5-12.8v
Dec 03, 2009 | Volvo 740 Cars & Trucks
My children played a game on the computer now my screen colors are fuzzy and distorted even the mouse looks funny i tried the menu botton on my computer it dident work i also tried going to he control...
Sounds like the resolution got adjusted. To fix this, right click on any empty space on your desktop, select properties, Then select the tab that says settings. There is a slider bar to adjust your resolution. The further you slide it to the right, the higher the resolution. With a higher resolution, everything will seem smaller and more defined.
If you're unable to adjust this to your liking or only have 1 setting, you may have to get a new driver for your video card.
Jun 24, 2009 | Microscan ADI 15 SVGA Monitor LM1564
Our Chevy 1989 S-10 seems to run good until we put it in gear, and try to drive. For awhile it was doing fine as long as we put a little pressure on the gearshift so it was at the top most part of drive....
I think the firstr thing you should do is check for loose ground wires, and wires that are being pinched. Check your battery cables for tightness on both ends. It seems like something is shorting out when your engine tips when you put it in gear. Check all the wires that are anywhere near the transmission. Good luck.
May 19, 2009 | 1987 Chevrolet S-10 Pickup
The light on the dashboard get's dim
Im not sure this will help,but theres a nob by your dashboard to turn the light (brightness) for the dash.and as far as the gear shifter the plastic plate pops off and you can see if the bulb is good
Nov 18, 2008 | 1992 Honda Prelude
Compaq Presario R3000 dimmed LCD screen
If your inverter is good I,de say your backlight is going bad, I just replaced mine in a sony vaio and now it seams to bright.
Oct 20, 2008 | Compaq Presario Notebook
My screen has dimmed but the cursor remains normal
I think its just like driver problem or you adjust the color in under advance button in the screen and resolution setting
takecare
Apr 28, 2008 | Computers & Internet
My screen is still dim after replacing the inverte
You may have inadvertently crushed or pinched a wire inside the monitor and this may have been your problem all along. Take the bezel around the screen off and see if your monitor comes back to normal. While it is off, look around the area for any signs of damaged wiring. If this was only a month old, why didnt you return it to have it repaired?
Aug 15, 2007 | Acer Aspire 5610-4648 Notebook
Dell AXIM Screen
First, to dim/undim the screen, hold down the power button for a few seconds. A quick press will turn it on/off. Also, when dimmed, if you tap the screen, it should be fully lit. FYI...to change the brightness in either the plugged-in or battery mode, hold in the scroll dial on the left-hand side and press the navigation button (big round one on the front) either up (brighter) or down (dimmer). As for the time, tap Start >> Settings >> System (tab) >> Clock and see if your time is off by 12 hours.
Sep 14, 2005 | Dell Axim X50 Pocket PC
Intel D945GCCR Motherboard Logo
664 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
