Question about GPS
Re opto coupler NEC 2501 LF217 what are the pin numbers, I know that pin one coresponds to the dot or circle, preferably let me have a drawing of the opto coupler showing the function of each pin. Thank you John
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Do you know where I could find these opto-couplers?
when you look into the back of the set you will see a small board on the far left. The large board right next to the small board is where they are located on that board usually near the back edge of the board closest to you roughly in the center. You can try at the following link just leave them an email with the model number of your set and what youre looking for, They usually can get the hard to find parts. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 16, 2008
My nec np-m300x has a dynamic contrast error. How do i repair this?
9 Blinks is IRIS error the motor can sometimes produce a clicking sound part number 24B17981. If you pull it out and manually move the metal apart the projector should come on and stay on
Jan 23, 2013 | NEC NP-M300XS- Xga Lcd Proj 3000lumen Shrt...
My tv tries to turn on but shuts right back off
SMPS circuit problem Check the SMPS . Replace opto couplers.
Do not switch ON TV without opto coupler in circuit. SMPS will go out of control and the + DC voltage will raise and spoil the circuits.
Sep 04, 2010 | Sanyo DS27930 27" TV
BLOWING FUSE , THE IX1791CE IS SHORTED
mostly this problem cause opto coupler is short. change the opto coupler and related parts like transistors,zener diode.and check all diodes&capacitors is power supply. you find any leaky or damaged part change it.
thank you
Sep 03, 2010 | Sharp 21B-S10 21" TV
Turn on but for 2 seconds only and then turns off again.
Check SMPS voltages. Check optical coupler. Check SMPS components. It is difficult unless you follow a circuit diagram.
Sometimes replacing opto isolator may solve!
Caution : Do not switch on T V without opto coupler. ( if you remove for checking ) replace with new one as it is difficult check with service test meter.
Aug 22, 2010 | Televison & Video
Tv turns itself off after turning it on
Check SMPS circuit.
Check for dry capcitors. Replace OPTO coupler in the feed back circuit in SMPS.
Do not switch ON TV without opto coupler fixed in circuit.
SMPS will go out of control and the + DC voltage will raise infinitely and damage the other parts. If transistors used along with the opto coupler, check them for leakage. Replace them. Otherwise the replaced opto coupler may fail again after few days or few hours of TV working.
Aug 19, 2010 | Sharp 19K-M100 19" TV
Philips Magnavox model # 9P5034C103
Thats usually related to the center opto coupler . I will research it and let you know the part number in an hour or so. Its a very inexspensive part and easy to replace.
Aug 03, 2008 | Televison & Video
Fatal error Code 16H
It relates to the transfer belt unit, replace it
Jun 04, 2008 | Konica Minolta Magicolor 2530 DL Laser...
May 16, 2008 | Televison & Video
Yes i need more help on these opto-couplers
The halo effect is due to the green and blue CRT coolant being congealed this is a common problem. Red will not have the same condition. As for the opto-couplers they are located on the large signal board in the middle of the board all lined up in a row they will have board location numbers of 7412, 7406 and 7413 . 7412 is usually the culprit the part numbers for 7412 is 9322-105-14682 7406 and 7413 are the same part number 9338-894-15682
May 15, 2008 | Televison & Video
GPS Logo
235 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
