Question about HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory
Hp laserjet 4650n
49,4c02 service error ( how can solve this problem) ?
    Novelist:
  • 125 Answers
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Posted on Jan 10, 2009
  • denge Nov 23, 2010
    I'm using an HP 4650n Color LaserJet. Just by turning the printer off, waiting a few minutes, then turning it back on got rid of the problem
How do I clean an HP 4650n printer
Can you be a little more specfic about what you want to clean. Outside? Inside? Do not use a regular vacuum to clean up spilled toner as it is so fine it will go right through the vacuum into the air and you will breath it in.
Aug 31, 2014 | HP LaserJet 4650n Printer
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Mar 17, 2014 | HP LaserJet 4650n Printer
Toner on transfer belt of an hp 4650n
Toner on the belt is normal unless it is interfering with the print quality. The belt cost around 300.00
Jan 14, 2013 | HP LaserJet 4650n Printer
Hp 4650 supply memory error
This is caused by a faulty chip on a toner cartridge, possibly the one that you last installed. Replace the toner cartridge
Apr 27, 2010 | HP LaserJet 4650n Printer
I have a HP 4650n and when I print there is line through the middle of paper or picture. Replaced cartridges and fuser. Not sure what to do.
Probable : Dirty paper Xport rollers
Possible : Main molibdene shaft scratched (if line always same position)
Feb 06, 2010 | HP LaserJet 4650n Printer
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
When trying to print on HP 4650 printer stops and displays 49.4C06 error code, how can I fix it? thank you
update the firmware first...if problem persists try removing the jetdirect card..if error goes away your jetdirect card will need replaced
Dec 16, 2009 | HP LaserJet 4650n Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory Logo
1,333 people viewed this question
Seeker5211
Seeker5211
