I agree with first answer. They can fail, 9 out of 10 times it's the motor itself, us. A complete laser unit with the motor inside will be over $100. The LSU will black, trapezoid a glass **** in the bottom facing towards the drum unit, on top it will have a yellow sticker warning about laser light and eye damage. It may be easy to disassemble or have security screws. Inside is the polygon motor with a bunch of mirrors and lenses, keep your fingers off them. The mirror motor will be mounted on a small circuit board about 3 x4 inches. It has to go back exactly the same otherwise the prints will be skewed. Pics of a typical motor... http://www.precisionroller.com/search.pHP
SOURCE: LSU ERROR shows in display panel
The LSU is the Laser Scanning Unit or "printhead". There is a mirror in there that spins really fast, if the mirror spins too slowly (bad motor, low voltage) it gives an error. Sounds like you would need a replacement LSU. Have the printer serviced.
Call the ASC, the mainboard is malfuntion and need to be replace.
SOURCE: Error message w/Samsung ML 2150 Laser Printer - Engine LSU Error
Your Laser unit at the top section where the paper exit is faulty. You have no choice but to change it.
SOURCE: engine LSU error printer model samsung ML2150
how can over come from LSU error problem in samsung all in one machines
