Kyocera KM-1500 has consistent paperjam in tray. It now so bad it just jams all the time and m/c no useless
  • 113 Answers
Remove the tray completely and clean the pick up roller using soap solution until it is clean. replace the casette and try copying.
Posted on Nov 13, 2010
How to insert bond paper in the machine
Dear Jonna
You can use any bond paper from casset tray up to 105 GSM and that of from MP tray you can choose up to 160GSM. Also setting to be made from the device driver for the type of paper as it require more heat energy to fix the image to the paper.
Thanks.
Jan 12, 2015 | Kyocera Ite-Tk-18-1 Tk-18H Toner Kit 7200...
What does the error message OP mean on my Kyocera mita KM-1500 copier?
From what I remember on this copier...... The software in the copier may be from another country.... OP or AP most likely the copier needs a new toner installed or could be a paper jam in the doc feeder. The codes were a bit messed up between different countries, I did not biuld them.... Good Luck
Dec 19, 2012 | Kyocera Mita Toner For Kyoceramita...
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
How do I fix error code j00 flashing?
J00 is flashing on my Kyocera KM-1500 copier, i checked but can't see any paper jam
Sep 26, 2010 | Kyocera Copystar CS-1620 Black and White...
My kyocera km 2020 has a j00 error how can i clear
Find the jammed paper in the paper tray.
Mar 10, 2010 | Kyocera KM-1510 Copier
When am try to get phoyocopy from KM 1500 kyocera machine its showing in display meter as an J 111
you have a paper jam in your copier... open it up and search.. best I can tell you...
Oct 07, 2009 | Kyocera KM-1505 Copier
Requist for sugasion kyocera km-1500 toner
it is support cnon np 1215 toner
first time
you clean copier toner unite clean complite previous toner then put canon np 1215 toner print ok
May 28, 2009 | Kyocera KM-1505 Copier
Copies are very light
check your transfer roller when removing the jam you broke the holder on the transfer roller and the contact spring fell out, no repair has to be replaced
Mar 26, 2009 | Kyocera Mita KM-5035 Printer
56 people viewed this question
jasbo
jasbo
