Question about Frigidaire Refrigerators
It is not defrosting automatically - Frigidaire Refrigerators
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Nov 13, 2010
Why does humidifier function shut off after 45 seconds?
bacause of the following reason
.Timing defrost by turning off:
When defrost sensor temperature defrost temperature (Parameter F2) and at the same time the defrost
interval time reaches the set value F3 then can enter to defrost, the fan will turn on, the compressor and
heater will turn off.
After worked a defrost interval time (Parameter F3) time, it will enter the stop mode automatically and
compressor will turn off.; after a defrost time(Parameter F1) will exit the defrost mode and enter to
automatic temperature control mode.
Mar 05, 2015 | Humidifiers
Where is the defrost relay button?
Frigidaire equips most of its refrigerator models with automatic defrosting capabilities. This means that owners don't have to set a calendar reminder to manually defrost. The internal automatic defrost control and timing mechanism is placed at the bottom of most Frigidaire refrigerators, next to the stationary panicon1.png that captures water - even the defrosted meltwater is automatically evaporated. You might be confused about how the defrost timer works, thinking it is broken. Frigidaire understood this might be an issue for some owners and suggests double-checking the defroster for normal operation because it may not be malfunctioning at all.
Read more: http://www.ehow.com/how_12165725_troubleshooting-frigidaire-defrost-timer.html#ixzz32x8RyDGe
May 27, 2014 | Frigidaire Ffhs2622mh 26 Cu. Ft....
MY MAGIC CHEF IWORKS FINE 2 TO 3 WEEKS A TIME ,AFTER 3 WEEKS IT STOPS COOLING - I REMOVE EVERYTHING OUT FRIDGE AND UNPLUG IT FOR A DAY ,A DAY LATER I PLUG BACK AND IT OPERATES FINE FOR ABOUT 3 WEEKS AND I...
Hi and welcome to FixYa, I am Kelly
Without your model number here is what most likely has happened:
The automatic defrosting system is not working due to a component failure.
The components of the automatic defrost system are:
1. Defrost control
2. Defrost heater
3. Defrost thermostat.
4. Wiring to inter-connect 1 - 3 above.
What your currently doing is a manual defrost cycle every 3 weeks because ice blocks the air-flow across the evaporator in the freezer compartment so everything starts warming up in the fresh food section first and finally the freezer as the ice block gets larger.
FYI you can unplug it... remove the contents from the freezer...use an external directed into the freezer compartment for just over 2 hours to do the same process your doing in 24 hours. Until the automatic defrost system is repaired you should do a manual defrost at least every 4 days.
Most units are on an automatic defrost cycle of 6 - 8 hours (usually) all the way up to 10.35 hours per cycle. Yours just is not working at all.
Thanks for choosing FixYa,
Kelly
Kelly
Aug 15, 2011 | Refrigerators
Have a GE tfx28ppdabb and the frig side gets hot, defrosted the freezer but the problem comes back after a week
Is it an automatic self defrosting unit? If so, defrosting the freezer will cure your problem temporarily. When the defrost timer fails to defrost automatically, ice builds up again and plugs the chute between the freezer and the fridge and the fridge gets hot.....If this action is repeatable,(meaning you can manually defrost but it only lasts a few days) then for some reason, the automatic defrost timer is not working. It's either the timer itself or one of the fuses.....there is always the chance that the thermostat, which tells the timer when to turn on and off, is also defective, but most of the time, the defrost timer is the culprit. Check the fuses first, then the defrost timer.
Jun 20, 2011 | GE Refrigerators
Hotpoint side by side not cooling & freezer is freezing up
Hi and welcome to FixYa, I am Kelly.
What your seeing is the result of an automatic defrosting problem. One of three things has failed
1. Defrost Control (most common failure)
2. Defrost Heating Element or
3. Defrost Thermostat
A refrigerator must automatically defrost 2 to 3 times a day or you will see the symptoms you are experiencing now. You can do a manual defrost by unplugging the unit and direct an external fan into the freexer compartment for just over 2 hours to get the temps down again. The only thing is after about 2 days the ice build up gets to the point that your freezer temps start warming up again. The correct remedy is to repair the automatic defrosting system.
Without a model number I can not provide you with the replacement part(s) source.
Kelly
Apr 13, 2011 | Hotpoint Refrigerators
I have a hotpoint future fridge - inside the door there is a black circle which used to have OK in the middle and it used to be green - this is now black - also the back of the fridge is frozen
Kelly
Apr 13, 2011 | Refrigerators
It seams to automaticly self defrost, draining into the trat below.
your refrigerator is supposed to defrost automatically, usually every six to eight hours depending on the type of defrost relay timer you have. Most timers are either six or eight hour. this is a normal condition.
Mar 17, 2010 | KitchenAid KSCS25FKSS Side by Side...
Automatic defrost no longer works
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 19, 2009 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
