Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
No picture Using the power button on the TV, I received 3 (or 4) slow blinks (green). After talking with a local repair tech, I unplugged the unit, waited 15 minutes & then plugged the unit in while the power button was depressed. I then received three fast blinks... Is this consistent with a flyback problem? I was told that it may be a power module & that they are difficult to find. thank you,
  • RCA Master
  • 8,617 Answers
No youre needing a flyback,3 Blink error is flyback. very easy to install takes about an hour start to finsih. You can get a new replacement flyback for less than 50.00 with free shipping at the following link and they will even explain how to change it by instant message with their techs for free. You need flyback 259296 for your model. heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 18, 2008
The green power light would come on, with no picture, for 3-5 seconds and then the power and the green light would turn off. I have reset the TV by unplugging for a little while but that has not helped.
When power light goes out on front of set press both the menu and input (device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 30, 2010 | Mitsubishi WS-55311 55" Rear Projection...
I have no power, i called a repair man, he said unplug it then push the reset button...i get a blinking green light for a few seconds...now what?
The set if it has a DM unit when unplugged should blink for 70 seconds and allow you to turn on.
If it does not, if when you try to turn on green light comes on and goes off---do the self check:
Press and hold both the menu and input buttons for 5 seconds and release both; power light should blink a two digit error code at least 5 times. 2 blinks, pause and 2 blinks is the most common.
If the set has a reset button on the front it has a DM unit---built in receiver--even if it fails the green power light will blink nonstop.
Again, if you try to turn on and green power light comes on and then goes off---do the self check and let me know what you find.
If this information was helpful rate this solution as "very helpful" as I do this here for free.
Also let me know what you do or do not find as I am here to help you.
REGARDS, SD TECH
Aug 11, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tv won't turn on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if it is 2,2 I have start to finish instructions for this repair in this model.
SD TECH
May 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
The green light on our mitsubishi tv WE-48511 turns green and turns on for about a second and then immediately turns off. The unit will not power up at all. any ideas?
PRESS AND HOLD “device”(or input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
if this information has helped you rate this solution as I do this here for free.
SD TECH
Nov 27, 2009 | Mitsubishi WS48511 48" Rear Projection...
The timer light keeps flashing but the tv wont come on
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver. There are also sites on the internet selling a kit for this repair.
If this information has helped you rate this solution as I do this here for free.
Let me know what more information you need--I am here to help.
SD TECH
Nov 10, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Green power light blinking-reset not working
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it pulls out and secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD Tech
Sep 29, 2009 | Mitsubishi WS-73909 73" Rear Projection...
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
