Question about Microsoft Windows Vista Ultimate Edition
Flexisign pro 7.5
Hi! i was using win xp with the above program but since i upgraded to Vista home pro i cannot get it to see my vinyl cutter/plotter is there a patch or other solution
    Sergeant:
  • 284 Answers
Write to the flexsign website
your only option, im sure they have something by now
Posted on Jun 18, 2008
How do i download the next upgrade after windows XP professional for free?
Why up grade if XP Pro is working fine???????? The only time to up grade is when your existing OS is not compatible with some program you wish to run. Other than that you should stay with XP.
If you have to "upgrade" your best bet is Win 7 but that is a clean install, not an upgrade. Stay away from Vista, Win 8.1, 10 lest you have horrific issues with convenience, compatibility and/or drivers.
Nov 14, 2015 | Microsoft Windows 8.1 - Windows
Is the ensoniq mr61 compatible with windows 8? Is there a device or upgrade for this?
Supported Operating Systems and Hardware MQ Essen
tials
Midi
Quest
Midi
Quest
Pro
Info 32-bit Windows support: Win 8, Win 7, Vista, XP checkyes.png checkyes.png checkyes.png 64-bit Windows support: Win 8 x64, Win 7 x64, Vista x64, XP x64 checkyes.png checkyes.png checkyes.png Windows Midi Quest x64 with x64 plug-ins to support 64-bit VST hosts checkyes.png Intel Macintosh systems: OS X 10.9, 10.8, 10.7, 10.6 and 10.5
Check this link
May 29, 2014 | Computers & Internet
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Windows xp
You don't need to buy another license for XP, you can use your old license.
Regards
Ashly
Feb 25, 2010 | Microsoft Windows Vista Home Premium...
I am having AVG Pro. on my Vista. Now I con't use
Go to AVG's homepage and look for a removal tool. Uninstall the software and download Microsoft Security Essentials...It's free and perpetual. You may also consider upgrading to Win 7 or downgrading to XP. Vista is the reason many folks are back to XP and Microsoft's reason for creating Win 7.
Nov 25, 2009 | Microsoft Windows Vista Business with...
Have deleted vista off toshiba satelite s2276, deleted all partitions, repartitioned to single large drive, formatted, booted from floppy, win 98 se setup started and working until installing drivers then...
If your system came with Vista pre-installed it is likely there are no XP or eariler drivers available for it, in which case you will have to stick with Vista or Windows 7.
Oct 28, 2009 | Microsoft Windows XP Home Edition
Getting a Blue Screen after upgrading with Win. Vista Business Upgrade from Win. XP Pro.
Restart the computer is Safe Mode (press F8 when booting to get a menu of options). This will start the computer with the minimum number of drivers and "extras" being loaded. From here you can press Win+R to bring up the Run command and enter 'msconfig' and press Enter. From this tool, you can allow your normal startup programs and device drivers to load. You will want to keep anything related to your DSL drivers disabled for the time being. Then restart the computer normally. If everything loads as it should, you can keep going back to the MS Configuration utility to add other drivers and programs one-by-one and retest (reboot again) to make sure everything is working properly. Once you know what the culprit is, you can uninstall that program and reinstall the Vista version if required. (If it is just software for your DSL modem, it probably is not required under Vista.)
Apr 14, 2009 | Computers & Internet
Flexisign pro 7 help:
best way is to use the beizer tool, image, vectorize beizer. if more clean up is needed use the path edit tools.... r click in a blank area of the tool bar and put a check mark in the path edit bos to turn it on....
Sep 03, 2008 | Microsoft Windows Vista Ultimate Edition
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows Vista Ultimate Edition Logo
757 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
