Question about Samsung Computers & Internet
Sir.I Have a Samsung 6SLM-43AG P3 Mother Board. ItsCan't Save CMOS Settings.I Do Change New Battery,Reset,etc But Not Save Settings..Pls Help Me
hughv
  • 196 Answers
SOURCE: Intel 815E Mother Board
Do you mean the Power Supply?
These are relatively cheap and easy to replace.
Posted on Dec 04, 2007
myob247
  • 1342 Answers
SOURCE: Sound Card Drivers Intel PENTIUM-4 865GV mother board
You can download your chipset drivers from Intel HERE which should include your audio and video drivers.
You may also require Microsoft's Direct X which you can get HERE.
Posted on Jul 07, 2008
  • 18 Answers
SOURCE: sound driver
go download the drivers from the following link
www.driverstock.com/ASUS-P4GE-MX-driver-download/6-9-10012/index.html
Posted on Jul 11, 2008
SOURCE: MOTHER BOARD DRIVER
Dear Sir,
I have installed windows xp sp2 and i have installed all the drivers of compaq desktop pc MODEL NO IS SG3430IL but i was unable to installed the display driver so, sir please guide me how i will install the driver its urgent.
Rgds
Bapi sarkar
Posted on Sep 15, 2008
asjsa
  • 36 Answers
SOURCE: NEED UR HELP
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
75
Posted on Mar 13, 2009
How to save BIOS and change mother board CR2032 Lithium battery
if you only take 5 to 20 sec you might not lose any bios Cmos settings
im not sure what or why you want to save the settings for
once the Cmos battery has been removed for more than 30 - 60 sec your cmos settings will be restored which means no password and failsafe defaults
you could just restore failsafe or optimised defaults if you lose any Cmos settings
you will need to reset the password and the time and date
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Oct 16, 2011 | Computers & Internet
Hello, when I put my pc running it says CMOS checksum error press F1 to enter or Del to enter setup, but I press Del when I save changes "save and exit" the computer restarts, but this time...
The Checksum error basically shows that boot settings which were previously set has been changed or reset. This usually happens when the battery loses its charge and thus fail to retain the CMOS settings. This can also be caused by a power surge or a damaged motherboard. But most of the times it would be the battery problem.
You can try replacing the CMOS battery and enter the values back into CMOS or reset values to default. Then switch off and boot up again.
Hope this works. Good Luck. ~SmokinJoe~
Apr 28, 2011 | EliteGroup KM400-M2 Motherboard
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
I have intel chipset mohterbord. i press start button.the smps fan running but mother bord led is not glow. no signal are find monitor pls help me.
Please remove the CMOS battery.Hold the power switch and fit the cmos battery . And go to set up BIOS,and set the bios fail save default.
Follow link.http://www.pcbuyerbeware.co.uk/BIOS.htm
If the problem is same Change the DDR1 RAM from ram slot from any running pc or new if you have a spare.
OPEN the BIOS chip using any thin pin and fit again tightly.
Follow link http://dexplor.com/phpBB2/viewtopic.php?t=7747553
You can change the SMPS or use it in another pc for test ,again the problem is same please change the MOTHER BOARD.
REGARD's
SHIBUDA
Jan 05, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
BOOTS FINE,SETUP CONFIG FINE, F10 TO RESTART NO CHANGES SAVED, PLS HELP
For that you need to change your cmos cell it gives voltage to mother bord flash memory so it save settings.
then save settings .
Aug 12, 2009 | EliteGroup K7SEM Motherboard
Sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Oct 11, 2008 | Computers & Internet
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Sound card
hello sir,
board is energy p3 pls check ur soung card model, to check ur sound card model in run command type dxdiag.exe and check sound detail if u found ur sound card detail go to google page type ur model of sound card and download .
Thanks for calling to us have a nice day
Aug 02, 2008 | Computers & Internet
Bios battery back up
You could try to reset the CMOS using the CMOS jumper settings near the battery, other than CMOS reset and replacing the battery there is no other way you can do to fix it other than returning it to the supplier. What you can do is to try to request a motherboard service unit in your supplier so that you can still use your pc until you are waiting for your motherboard.
Jun 18, 2008 | ASUS K8V-MX Motherboard
CMOS Checksum error - Defaults loaded
When the CPU speed stored in BIOS and the actuall speed of CPU differs then this error comes.
To fix this you have to select the actuall speed of your attached CPU to the board. Just set the actuall speed and save the changes. It will fix your problem.
Thanks
Iqbal
Mar 23, 2008 | EliteGroup P6STP-FL Motherboard
Computers & Internet Logo
150 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
