Question about Motorola Mobility HS850 Consumer Headset
PAIRED MOTOROLA BLUETOOTH WITH SAMSUNG
CANNOT GET BLUETOOTH TO FIND MY PHONE
How can i install my motorola hs850 to my samsung sgh-t429
Posted on Jan 02, 2009
Hold down the connect button on the bluetooth tl the light stays on, then open the boom, release the button. The light should stay on now, and your phone should be able to find you bluetooth.
Posted on Jul 01, 2008
SOURCE: pairing samsung wep200 bluetooth with motorola V3xx Razor
hold that reciever button until the light is a still...you may have to hold it for about 10seconds and once the still blue buton has come then search for devices on your phone.
Posted on Dec 27, 2007
SOURCE: Bluetooth pairing
space.gif answer.gif Before you can use your headset, you must pair (bond) it with your phone. Below are general Motorola headset pairing instructions to a mobile phone:
Step A. Start Bluetooth on your phone.
Note: These steps are for most Motorola phones. See your phone's user guide for more details.
  1. Press Menu (Center Select Key).
  2. Scroll to and select Settings.
  3. Scroll to and select Connection.
  4. Scroll to and select Bluetooth Link.
  5. Scroll to and select Setup.
  6. Scroll to and select Power
  7. Press Change.
  8. Scroll to and select On.
Step B. Ensure headset is in pairing mode.
Power on the headset. The indicator light flashes to initiate easy pairing. After a few moments, the indicator light will be steadily lit in blue to indicate headset is in pairing mode.
Step C. Set your phone to find your headset.
Note: These steps are for most Motorola phones. See your phone's user's guide for more details.
  5. Scroll to and select Look for Devices. The phone lists Bluetooth devices it finds.
  6. Scroll to and select Motorola [Device Name].
  7. Select OK or Yes to pair your headset with your phone.
  8. Enter the passkey: 0000
  9. Select OK. When your headset successfully pairs with your phone, the indicator light changes from steadily lit to flashing blue.
If lost connection or stopped pairing delete blue tooth item and reinstall as above
Posted on Dec 30, 2007
SOURCE: pairing my bluetooth to my phone
The Passkey for any bluetooth is 0000 so if you put that in it should work.
Posted on Jan 03, 2008
SOURCE: samsung bluetooth device pass key ?
key 0000
Posted on Oct 08, 2008
SOURCE: pair my samsung bluetooth to my blackberry cel phone ,
i found out that if you turn the bluetooth off and then turn it back, while turning it back on hold it until solid blue light and then try 2 connect with your blackberry i jus got mine and threw my instructions out. and i did this and it worked and if it should ask for a passcode i used 0000.
Posted on Oct 14, 2008
Jawbone bluetooth won't pair with phone.
sometimes the phone will not pick up on certain bluetooth headsets so i recommend a Motorola.
Apr 28, 2009 | Samsung SPH-m520 Cell Phone
Having problems pairing
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 12, 2009 | Motorola Mobility Universal Wireless...
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
HOW TO PAIR MY MOTOROLA H500 TO SAMSUNG CELL PHONE?
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Dec 26, 2008 | Motorola Mobility Bluetooth Hands Free...
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
Pairing bluetooth with new phone
You have to hold the on button until it is a solid blue light not flashing 5 or 6 seconds then it is ready to be paired.
Jun 21, 2008 | Motorola Mobility H300 Wireless Headset
How to pair a Motorola D200 to a phone??
You will never be able to pair the d200 to a phone or another device, for this is a a2dp bluetooth dongle, that´s why it works with your headphones.
Mar 07, 2008 | Motorola Lands Phones
Compatibility and setup
when you pair them up have them about a foot apart they can be a bit temprimental but they do pair up.
Nov 16, 2007 | Motorola Mobility RAZR V3
Motorola Mobility HS850 Consumer Headset Logo
103 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
