Question about Roland Audio Players & Recorders
Roland amps can I connect a roland kc300 to a kc350using the sterio link or do thay have to be the same power of amps
  • 1,512 Answers
Hi rockbert
Yes you can do this. the only drama you may have is at high levels where one amp may begin to clip and distort before the other. If you are trying to run a stereo setup, you could counter this to some degree by adjusting the bigger amps gain down to the same level as the smaller amp if needed, giving you control over the "stereo balance".
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 19, 2008
Is it possible to connect my Boss multiple effects ME-25 to my BR-800 recorder. If so how, and can it then be linked to an amp (again how)
Hi
I have found manuals for both and looking at these I can see no reason why they shouldn't connect to each other. I am not a music expert but deal with computers. I would suggest that you try the external amp connection to connect the ME-25 to one of the BR-800's inputs, and then connect the "line out" of the BR-800 to an amp. Also make sure that during the connection operation, all power to the four units is OFF and the levels are all set to zero. By doing this you can minimize any danger of overloads anywhere in the system when you do "Power on". To help you confirm what I have said, I give below the links to the manuals which can be downloaded in pdf format and saved to your computer for reference as you connect up, and for any queries in the future;
ME-25 Multi-Effects :- http://cmstest.roland.co.uk/assets/media/pdf/ME-25_egfispd01.pdf
BR-800 Recorder :- http://lib.roland.co.jp/support/en/manuals/res/39599043/BR-800_e04.pdf
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 20, 2014 | Boss Music
Tip
No audio even though sterio wires are all connected
My 1997 Alpine CDE-7828's wiring schematic doesn't disclose one important thing for many older and possibly even some newer sterios (aka 'head units'). If all wires are connected per the sterio's schematic andf sound is missing, you probably have a dedicated pin on yout vehicle's harness/connector that will read something like 'Turn-on AMP signal", <br />until you jumper the ignition hot lead (between the harness plug and your sterio) to your vehicle's 'Turn-on AMP signal' pin/connector wire (add a wire if none is supplied in your vehicle's connector), you won't get any sound even though all the other wires are connected per your head unit''s instructions.
on Nov 06, 2010 | Car Audio & Video
I would like to know how to properly connect my roland kc350 to my yamaha p90 for execellent stereo sound. seems like the sound is not quite perfect when i plug into left/right inputs on amp from...
Correct connections to connect your keyboard to your roland amp, and then the amp to the PA would be:
Two mono 1/4" jack (regular guitar leads) leads to connect the sockets labeld L and R on your P90 into channel 2 L and R on your amp. (channel 2 is better as you cannot overload it like you could on channel one, which has enough gain for microphone)
Then, using either the jack or XLR (XLR would be better if your PA mixer can accept them) sockets on your amp labeled LINE OUT, hook up your roland amp to your PA. Make sure to use the correct line outs on the top panel, NOT the stereo link or Sub outs on the back.
May 04, 2011 | Audio Players & Recorders
Hi,I just bought a Roland FS 1 footswitch.I have a Laney AOR 100 tube amp which takes a Laney FS 1 footswitch.I was hoping the Roland would work with my Laney but it doenst.I bought the Roland used as well...
OFTEN Roland has the opposite sense of normally closed contacts versus normally open. Test the switch with any continuity tester or an ohmmeter to see that the contacts work and come out to the switch. ALSO some amps require a TRS type connection (three wire plug) and others do not. From the schematic it appears that the Laney may REQUIRE a normally closed contact. There is also a pull switch involved that you MAY have to change the state of for operation of the pedal.
Here is the scheamtic for your amp:
http://elektrotanya.com/laney_aor100h_sch.jpg/download.html
Scroll down to the link at the page "Get Manual" and click to download. It is a JPG type file.
Apr 22, 2011 | Roland FS1 Footswitch Pedal Switch
My amp jl audio 500/1 i connect it and the green light turn on then i turn in the sterio and it sounds but when i turn off the sterio and when i wanna turn it on again the amp dont turn on i dont know why
Check the remote lead and see if it is getting power at the amp when it won't come on that way you know if the issue is with the head unit or the amplifier.
Mar 08, 2011 | Jl Audio 500/1 Car Audio Amplifier
The unit is in excellent shape, not used much and has been kept in the oringinal box. I got it out today and the power won't come on? I put brand new batteries in it and still no power. It has been...
Check for corrosion on battery contacts. If this unit can use an AC adapter, often the switch contact in the power plug that connects the batteries when adapter is removed gets bent and fails to connect the batteries.
Dec 19, 2010 | Roland Boss Dr670 Dr Rhythm W Bass Sounds
HI My Rowland Kc60 suddenly has no power. I presume it is shorted out...can I replace the fuse myself, and if so - where and what fuse do I buy and how do I access it on the amp?
Here is a link to the manual:http://lib.roland.co.jp/support/en/manuals/res/1811247/KC-60_e2.pdf Page 9 states that there is a protection circuit built into the power supply. Follow the directions for turning the power on in the manual. If the amp doesn't power up you will have to have it serviced by a qualified Roland tech as there is likely to be some damaged circuitry that won't be repairable without the schematic, parts and safe repair procedures.
Oct 18, 2010 | Roland Kc60
How do i hook up a B4.250.2 Amp to a home sterio?
Hello umbaftroml,
Here's a link to the owners manual: Scroll down to the B4.250.2 and right click "Download Manual".
http://www.lightningaudio.com/scripts/latech.cfg/php.exe/enduser/std_adp.php?p_sid=572kxbvj&p_lva=&p_faqid=154&p_created=1235512138&p_sp=cF9zcmNoPSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9OTEmcF9wYWdlPTE*&p_li=
You'll need some source of 12V DC power which is not available on your home stereo. A 12V battery or DC power supply will work OK. You'll also need to wire in a toggle switch to "trigger" the amp to turn on. Just put the toggle switch inline with a diode for isolation between the power wire and the "remote" terminal on the amp. Flip the toggle on when you need to use the amp.
The speaker connections and source connections are all shown on page 6 of the manual and would in any case, be the same as if you were installing the amp in a vehicle. Be aware that most home stereo speakers are 8 ohms, whereas speakers and subs designed for vehicles are usually 4 ohm or sometimes even 2 ohm. This will not be a problem. you shoud be able to drive 8 ohm speakers, they just won't be as loud because the amp will not produce it's full power into an 8 ohm load. Plug your RCA's into your home stereo's preamp outputs, or if there are no preamp outputs, use the speaker level inputs on the lower edge of the amp.
Hope this helps.
Apr 13, 2009 | Lightning Audio B4.250.2 Car Amp
JBL CS60.2 Car Amp is fitted to new sterio but stays on 247 regardless weather the car is on/off or even when sterio is off... so stays on during the night ¬¬
The blue wire to your amp (remote signal wire) needs to be connected to the red power lead for your deck. Right now it sounds like you are connected to constant power on your signal wire.
Apr 04, 2009 | JBL CS60.2 Car Amp
Rd-700
power amplifier will increase sound level-try graphics equalizer and connect it between the roland and the mixer(ask sales man which equalizer is more suitable for use with roland and behringer.
Jul 18, 2008 | Audio Players & Recorders
Open Questions:
131 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
