Question about Memorex Audio Players & Recorders
WHERE TO GETmanual fof Memorex USB TURNTABE 2650MM
Good day. I have a memorex ultratravel drive USB 2.0 160GB. Everytime I connect to any computer I get the message:The pc does not recognize the USB device code 43. Please let me know what i can do. thanks...
Code 43 is the death code - the pc simply cannot communicate with the attached device because the device is not working. This means that the Memorex is dead . Since the electronics board inside it cannot be repaired or replaced it means that yo must buy a new one.
Apr 09, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
Memorex mmp8585c problem : USB not recognised
I would suggest you to connect the player to another USB ports and computer if possible. Make sure the USB cable is properly connected to the port. If you get the same results, the player is probably no longer able to connect to the computer.
This product has a 90 day warranty from the purchase date. You can try taking it back to the store or contacting Memorex at 1-877-363-6673.
Sep 01, 2010 | Memorex Computers & Internet
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
Can i install a turntable to my technics sc-dv290
ION has just released a turntable that connect via USB! You can now play your lp's on anything that accepts usb cables. It is available at Bed, Bath, and Beyond. Also, there are many various turntables available that connect via RCA cable. Bet Buy and Circuit City both carry mdels that will hook to your unit via RCA cable. They have some models on sale at times for under $90 bucks! Thanks for using FixYa! And don't forget to rate my solutuion! Good luck, and Happy listenng!
Jan 13, 2009 | Technics SC-DV290 System
Memorex mmp8567 boot error shutting down
My MMP8567 screen read ''boot error shutting down''.
Update the firmware. Download directly from Memorex site, Support section.
Everytime I plugged it in to the computer the computer would find it but then it would disappear almost immediately.
I downloaded the Updater program from Memorex but it couldn't find the player.
The directions from Memorex said ''Hold down the play button and plug in usb cable.'' Another set of Memorex directions said, ''Hold down the power button and plug in usb cable.'' Neither worked for me.
SOLUTION: I finally held down the LOCK/UNLOCK button and plugged in the usb cable. My computer found the player immediately and a software driver window popped up asking for a driver. I let windows search the internet and it found and installed the driver. The driver it was looking for was: ''player recover device class driver''
After windows confirmed it recognized my mp3 player I started up the Firmware update program and was able to update the player.
I tried to be clear and detailed. Good Luck ;-)
Nov 30, 2008 | Memorex MMP8567 MP3 Player
Usb cable for digital audio player.
Its just a generic USB cable -- try Radio Shack.
Jul 15, 2008 | Memorex MMP8585 Digital Media Player
I HAVE A MEMOREX (MMP8640A) AND IT WON'T COME ON.
reinstall the firmware, following the next steps:
Download the firmware from Memorex site (www.memorex.com) but use the firmware for MMP8620 NOT the one for MMP8640, otherwise you will finish with your player starting with a blank screen.
FIRMWARE UPDATE INSTRUCTIONS FOR MMP8640.
1. Make sure the unit is powered off.
2. Plug one end of the USB cable into the USB port on your PC.
3. Click on the start button on the lower left hand corner on you PC.
4. Highlight Programs, on the drop down page highlight Memorex Aptitude Digital Audio Player.
5. On the drop down window click on “Memorex Aptitude Firmware Download”.
6. Memorex Aptitude Firmware Download Window will open with a notice “PLEASE CONNECT
DEVICE”.
7. Press and hold down the MENU button on the MP3 player at the same time connect the other end of the
USB cable to the USB port on the player.
8. Firmware Download Window will begin initializing.
9. Keep holding down the MENU button on the player until the Firmware Download Window displays
“READY”.
10. Release your finger from the MENU button.
11. In the Firmware Download Window, put a check mark beside Format Data Area.
12. Click on the START button in the Memorex Aptitude Download window.
13. Wait until the screen says “firmware download complete”.
14. Click on the CLOSE button.
15. Disconnect the USB cable from the player. The player will turn on by itself. If the player doesn’t turn
on automatically, press the power button.
Please note if an ERROR message appears on the display of the player when the player powers on, you
need to repeat steps 1 - 15.
WARNING: DO NOT INTERUPT FIRMWARE DOWNLOAD PROCEDURE
Hope it helps, I solve the problem just like this.
Jan 08, 2008 | Memorex MMP8565 MP3 Player
Memorex PS/2 mouse
JUST GO ON EBAY AND YOU WILL FIND THE LEAD THAT YOU NEED
Nov 07, 2017 | Memorex (3202-2362) Mouse
24 people viewed this question
Top Memorex Audio Players & Recorders Experts
Greg Cann
Greg Cann
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
